- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Samba Frustrations
- Mark as New
- Bookmark
- Subscribe
- Permalink
Samba Frustrations
Windows 10 1709 (Build 16299.125)
ReadyNas Pro 6 (Radiators 4.2.31 )
Windows 10 upgraded to 1709 (Build 16299.125), after which I find Samba v1 has been removed and I can no longer connect to my Readynas Pro 6 (Radiators 4.2.31 ) shares. I search most of the threads, however I did not find a concrete solution on enabling and configuring Samba V3 on the Readynas Pro.
Best, thread I found was (https://community.netgear.com/t5/Using-your-ReadyNAS/SMB-1-0-Given-Wanna-Cry/td-p/1283738) which mentions adding “server min protocol = SMB3” to the /etc/frontview/samba/smb.conf.overrides file (FYI – file did not exist so I created it). Reboot system, but no dice.
The thread also mentions installing SMB Plus, which I could not find for radiator 4.2.31. Is there a version around somewhere I could use?
Are there any specific instructions on getting this work and configuring Samba?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Samba Frustrations
The version of samba in RAIDiator 4.2.31 has experimental support for SMB2, but not support for SMB3.
SMB Plus is an app for ReadyNAS OS 6.
It sounds like you should either re-enable support for SMB v1 on your PC or consider upgrading to OS6 even though it's not supported (don't forget to make sure your backup is up to date first as you will need to restore that).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thought about enabling Samba v1 on the OS, I cant find the service that enables it(does not apear to be installed. although Micrsoft pages say it can be re-enabled.
Before i do the upgrade to 6 (it will take days to back up the data), how can SMB v2 be enable on the readybnas?
BTW - thank you for the assistance
- Mark as New
- Bookmark
- Subscribe
- Permalink
TLDR; try this and reboot
Open administrator cmd prompt
dism.exe /Online /Enable-Feature /All /FeatureName:SMB1Protocol
for some reason the forum keeps putting the emoticon, see also @ https://www.reddit.com/r/sysadmin/comments/7ac3mo/how_can_i_reenable_smbv1_in_windows_10_1709/
- Mark as New
- Bookmark
- Subscribe
- Permalink
Emoticons are special character sequences, and generally start with :
I avoid the accidental emulation by bolding the colons - I took the liberty of doing that with your post.
On the main issue, turning on SMB1 is done in Windows 10 by
- Entering turn Windows in the search bar. Turn Windows features on or off should appear at the top. Select it.
- Scroll down the features list, and you will find SMB 1.0/CIFS File Sharing Support. Click on the + next to the checkbox.
- Then you will see SMB 1.0/CIFS Client and SMB 1.0/CIFS Server as separate entries.
- To simply access the NAS, check the client box and click ok.
If you want to back up a PC share to the NAS with the Frontview backup jobs, you'll need to enable the SMB 1.0/CIFS server also. That carries a higher security risk for the PC, so I suggest using a different way to back up the PC (Acronis TrueImage, FreeFileSync, or some other package that runs on the PC).
After you enable the SMBv1 client, you might also find that you need to enter NAS credentials into the Windows Credential Store. If your NAS isn't using user-mode authentication, you should switch to that mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Had already tried most of these solutions to no avail usually i get this
Feature name SMB1Protocol is unknown.
A Windows feature name was not recognized.
Use the /Get-Features option to find the name of the feature in the image and try the command again.
also tried
Enable-WindowsOptionalFeature -Online -FeatureName smb1protocol
and no go.
Pretty much not matter what i tried, i could not install it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you see it listed when you look in "turn windows features on or off"?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried that also, protocols are not listed in the list.
- Mark as New
- Bookmark
- Subscribe
- Permalink
also tried
and no go.
Do you see it in powershell when you run it as administrator?
That is, Get-WindowsOptionalFeature –Online –FeatureName SMB1Protocol
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes, all commands were execuated on a elevated Powershell window. the OS woudl otehr complain stating it needs elevated privileges.
Althouugh i am not get symtoms of a full blank features list, i am trying the steps below to see it helps.
https://www.addictivetips.com/windows-tips/fix-blank-turn-windows-features-on-or-off-list/
- Mark as New
- Bookmark
- Subscribe
- Permalink
There might be a GPO that's blocking it. So maybe also look here: https://blogs.technet.microsoft.com/staysafe/2017/05/17/disable-smb-v1-in-managed-environments-with-...
