sluicegates
Nov 27, 2018Aspirant
URGENT. File shares disappeared.
RN214, bought in May 2018 and registered with Netgear. 4 new 6TB WD RED drives bought in May.
Worked fine until today - when all my shares are invisible. No system updates since yesterday, and no other users except me. All connected to Nighthawk Router.
ReClaiMe can see my lost files (I tried that) and can play the audit, but will charge $199 for recovery. Not acceptable for data I already own, and on drives that the NAS tells me are healthy and with data on them. What happened since yesterday??
FYI - Approx 12GB of not-for-profit recording studio data currently inaccessible (sluicegatestudio is a nfp org).
Netgear - what is the reason for this? will you cover the $199? I think you should. Or provide a solution.
Formal response from Netgear please.
I'm not Netgear, but I suggest that you post the firmware version you are running on the NAS.
Also, the all my shares are invisible comment could use some clarification. Do you mean that the shares aren't shown in the admin Web UI? Or that you aren't seeing them in File Manager or Finder?
- sluicegatesAspirant
Thanks for replying, appreciate it.
Firmware is 6.9.1 Hotfix1
All shares have disapeared in Web UI, Drives reporting healthy, with data capacity showing as being appropriately used. I can see *some* of them in WIndows explorer (some of the mapped drives - but not all).
Am Exporting the drives and doing data recovery, which is arduous, but seems to be fine - all data is there and drives are healthy using WD diagnostics etc.
Have you tried accessing the NAS data volume with file explorer/finder? You can do that with NAS admin credentials. Once done, check to see if the missing shares are showing up there. Note that you can only use one windows credential from a PC at at time. There is a trick though- if you are mapping the drives using the NAS host name, then you can map them using the IP address with admin credentials (or vice versa).
Also, is the system have an indication of a full root volume?
