Paul8's avatar
Paul8
USB connected UPS
Had been using Cyberpower CP1500AVRLCD UPS for the last couple of years with this ReadyNAS thru a USB connection.  Sometime this year with the firmware update now at 6.9.1, the USB connect to UPS appears no longer supported.
Tried adding UPS and there is no USB option.  The only options are SNMP and Remote UPS.  Please advise how I can configure the UPS using the USB option that was available in the past.  Thanks!
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    A UPS connected via USB should be automatically detected and used without needing any configuration.
    • StephenB's avatar
      It should show up if you expand the UPS section of the power tab.  I did that, and then clicked on the settings wheel, and see this:
      • Paul8's avatar
        Paul8
        Thank you for your suggestions. Just changed the UPS USB connection to the rear USB instead of the front and now it recognized it.  Not sure why it does not work with the front USB.
ProSupport for Business
