ankitrana's avatar
Feb 05, 2020
Unable to mount Mediasonc Proraid HUR5SU3 USB drive(s)
Hi,
I have a mediasonic proraid device with two HDD (4TB each) configured as single to show up as separate USB devices.
I have used this before and it used to work perfectly, and now for some reason it does not show up both devices but randomly shows up either 1 of 2 HDD as usb.
I googled around and some suggested to SSH and mount the device but that is not what i want to do... hesitatingly i SSH into the ready nas. With absolutely limited knowledge of anything tech is just found out that it is indeed discovered but not mounted.
I have another Seagate USB plugged in and thought may be it is due to another USB attached, i tried it with Seagate USB connected and all the USB ports but the result is same.
READYNAS 214
ReadyNAS OS: 6.10.2
blkid output:
/dev/sde1: LABEL="SBPD" UUID="C2E83C85E83C79AD" TYPE="ntfs" PARTUUID="687ec70f-01"
/dev/sdg1: LABEL="EFI" UUID="67E3-17ED" TYPE="vfat" PARTLABEL="EFI System Partition" PARTUUID="b21fb00d-b96d-4c56-9221-4d9be8363692"
/dev/sdg2: LABEL="T3" UUID="4430AF6030AF57A6" TYPE="ntfs" PARTUUID="1e3c1068-b528-4f5f-8892-2e4fe97a2e3e"
/dev/ubi0_0: UUID="523402c5-1fde-4e21-8c12-d6280c228fcc" TYPE="ubifs"
/dev/sdf1: LABEL="EFI" UUID="67E3-17ED" TYPE="vfat" PARTLABEL="EFI System Partition" PARTUUID="a1dc84ab-bafb-4995-9ca5-20c677bbc796"
/dev/sdf2: LABEL="T4" UUID="188CADA78CAD7FBC" TYPE="ntfs" PARTUUID="6fc1405c-8b98-4ebc-9ce2-52279285306f"
df -h output:
Filesystem      Size  Used Avail Use% Mounted on
udev             10M  4.0K   10M   1% /dev
/dev/md0        3.7G  918M  2.6G  26% /
tmpfs          1009M     0 1009M   0% /dev/shm
tmpfs          1009M  3.4M 1006M   1% /run
tmpfs           505M  1.1M  504M   1% /run/lock
tmpfs          1009M     0 1009M   0% /sys/fs/cgroup
/dev/md127      3.7T  516G  3.2T  14% /HD1
/dev/md126      3.7T  1.3T  2.4T  35% /HD2
/dev/md126      3.7T  1.3T  2.4T  35% /home
/dev/md126      3.7T  1.3T  2.4T  35% /apps
/dev/md124      3.7T  210G  3.5T   6% /HD4
/dev/md125      3.7T  924G  2.8T  25% /HD3
/dev/md126      3.7T  1.3T  2.4T  35% /var/ftp/SDL
/dev/md125      3.7T  924G  2.8T  25% /var/ftp/test
/dev/md124      3.7T  210G  3.5T   6% /run/nfs4/HD4/Ankit
/dev/md127      3.7T  516G  3.2T  14% /run/nfs4/HD1/download
tmpfs           4.0K     0  4.0K   0% /home/admin/snapshot
tmpfs           4.0K     0  4.0K   0% /home/uNAS/snapshot
/dev/sde1       1.9T  1.4T  505G  73% /media/USB_HDD_1
/dev/sdg2       3.7T  1.5T  2.3T  39% /media/USB_HDD_3
SBPD is Seagate backup plus device (another USB)
T3 and T4 are the two disk label for Mediasonic USB device
i dont even know how to mount them and is looking for some guidance. If need more outputs to be shared please share the command as i might know how to do that
TIA
  • ankitrana wrote:
    So there you have it....well why does it say so ??
    The NAS does support NTFS (your other drives are formatted that way).  But it does use a third-party package to do that.
    I'm guessing it might be the Paragon software.  If I'm right, then
    # mount -t ufsd /dev/sdg2 /media/USB_HDD_3
    might work.
  • StephenB's avatar
    As you can see from the df command, normally it would be mounted as /media/USB_HDD_x
    So you can look in /media, and find a USB_HDD folder that isn't being used (for example USB_HDD_2), and try mounting with
    # mount /dev/sdf2 /media/USB_HDD_2
    Then see if the expected files and folders show up in /media/USB_HDD_2.
    However, this might not be enough to access the drive with file explorer or the web ui.
    • ankitrana's avatar
      ankitrana
      Tutor
      Hi there, first of all thanks for your response, really appreciate it.
      So i had all the USB drive plugged out, so after pluging in "the USB", this time around the other drive came up.
      Output of blkid:
      /dev/md124: LABEL="601d24b6:HD4" UUID="e4dcb617-f0d1-4893-98d3-e1133fcf72fa" UUID_SUB="4d52c64a-0014-49b5-a871-140d19cbe9a2" TYPE="btrfs"
      and of df -h
      /dev/md0        3.7G  916M  2.6G  26% /
      /dev/sdf2       3.7T  577G  3.1T  16% /media/USB_HDD_4
      so i modified your command and ran
      root@BhaiyaJi:/home/admin# mount /dev/sdg2 /media/USB_HDD_3
      mount: mount point /media/USB_HDD_3 does not exist
      root@BhaiyaJi:/home/admin# ls /media/
      USB_HDD_4
      so i created a new folder and tried to mount
      root@BhaiyaJi:/home/admin# mkdir /media/USB_HDD_3
      USB_HDD_3  USB_HDD_4
      mount: unknown filesystem type 'ntfs'
      • StephenB's avatar
        might work.
ProSupport for Business
