- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Upgrade Readynas Pro 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Upgrade Readynas Pro 6
Thank you for the insights. AES isn't available in any of the lga775 processors afaik, so a processor upgrade won't help with that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The x3230 is basically a q6700 with performance almost like a q9400:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, i'm using stock fans.
@CJDEN wrote:I was also considering the 3230. Are you using the Stock fans?
I just picked my cpu from some old project i had..
Fastest possible with the lowest TDP... 95W against 105 on the q6700.
I can't remember the cache size but i think it's a bit larger on the 3230.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yep, a faster processor will definitely speed up things, but since there are no dedicated AES instructions in the cpu, the software can't take advantage of that (if it is even written for that).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good day @viperhansa
Are you running the X3230 on the ReadyNAS Pro 6?
I want to upgrade ram up to 8gb on my RNDP6350.
Could you suggest the exact model of the DDR2 RAM?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 4
On-line CPU(s) list: 0-3
Thread(s) per core: 1
Core(s) per socket: 4
Socket(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 15
Model name: Intel(R) Xeon(R) CPU X3230 @ 2.66GHz
Stepping: 11
CPU MHz: 2659.863
BogoMIPS: 5319.72
Virtualization: VT-x
L1d cache: 32K
L1i cache: 32K
L2 cache: 4096K
What kind of memorymodules i use i cannot remember, except it's a matched pair of 4GB crucial. (2x4GB)
Not at home so i cannot check.
regards
Hansa
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't think Crucial is making 4 GB DDR2 modules anymore (at least they aren't on their website). Finding compatible 2 GB modules is much easier (and cheaper). Note you can't use high-density modules (often labeled as "AMD").
Several years ago I went with Patriot PSD28G800K, which has worked well. But there's not much out there, and it is quite expensive at the moment.
I think this will work: https://www.ebay.com/itm/A-Tech-8GB-2-x-4GB-PC2-6400-Desktop-DDR2-800-MHz-240pin-DIMM-Memory-RAM-8G-...
Hopefully @Sandshark will chime in.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@StephenB
Was a long time ago i upgraded so that is possibly true.. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
That RAM does not say if it is 2Rx8 (low density) or 2Rx4 (high density). But based on the chip count, I think it's low density and will work.
But you will see almost no improvement from 4GB to 8GB unless you are running a number of memory-intensive apps, so the expense is something you should really evaluate.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you could find out those crucial part numbers, that would be really great. Even though it may not be possible to buy them new, I'm sure they would turn up at a reasonable cost in the used market since no one would know they were special.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for that Patriot part number--seems like those are available on ebay used. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
In my experience it's next to impossible to find 4gb modules that are low density. I have some high density modules and when I tried them each only showed up as either 128mb or 256mb.
But even just as a basic nas unit, memory increases improve performance quite a bit. After moving to just 4gb of memory, mine now maxes out gigabit easily. And I've checked top when I've ssh'd in and the memory is being utilized too, mainly for caching and buffers, which would hellp with performance boosts.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have tested two different ram modules.
(4GB) It didn't work:
(2GB) It works:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can't see the pictures. I would try those patriot modules since they are known to work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
M395T5160QZ4-CF7 4GB
It didn't work.
PLEXHD PC2-6400-CL6 2GB
It works.
I can't say anything about the Patriot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
They've been running for some years in my Pro-6.
I did a little googling on this forum, and here are the options posted here (that users reported worked):
- Patriot PGS28G6400ELK
- Patriot PSD24G8002
- Patriot PSD28G800K
- Hynix HMP351U6AFR8C-S6
There likely are more at the old forum site ( www.readynas.com/forum ), but that is only on wayback now, and you can't search it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The M395T5160QZ4-CF7 is registered memory, which does not work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for posting these. 🙂 I looked up my notes and apparently there are some particular gskill modules that work as well. I'll see if I can't find the part numbers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have sucessfully used GSkill and OCZ. Frankly, as long as you pay attention to the specs (like avoiding the registered one listed above), I've not found anything that doesn't unless it's just a bad stick.
- « Previous
- 1
- 2
- Next »
