dsnpevl's avatar
dsnpevl
Virtuoso
Dec 28, 2018
Where is the UPS option in the ReadyNAS Admin page?
The ReadyNAS OS on a RN516 with firmware "6.4.9 hotfix 1" is not showing a UPS configuration option. Or at least not in System -> Settings, where I expect it to be. I want to connect an UPS to the RN516, but without this option, this will prove difficult.
Any tips on how to get the UPS option to show up, or where to look for it?
  • My bad. Read somewhere that it should be in System -> Settings, but that is probably old information. It now lives in System -> Power, as rightly marked out by StephenB.
    So it's working as expected. Thanks for your help! Will start looking into the configuration options now.
    System -> Power -> UPS
  • StephenB's avatar
    It should configure automatically when you connect the USB cable to the NAS.
    • dsnpevl's avatar
      dsnpevl
      Virtuoso
      Hi StephenB,
      No, it doesn't. But it does show up in upsc, so RN516 is detecting APC UPS at some level.
      # upsc UPS@localhost
      device.mfr: American Power Conversion
      device.model: Back-UPS RS 1200G
      ups.mfr: American Power Conversion
      ups.mfr.date: 2018/09/06
      ups.model: Back-UPS RS 1200G
      Can I use one of the back USB, or shoud I use the front USB?
      Will check if power-off and restart triggers the auto detection by the Admin Page.
      • StephenB's avatar
        So the network UPS tools is detecting it.  You are saying that you aren't seeing it on the power tab when you expand the UPS section?
ProSupport for Business
