unita's avatar
unita
changing raid type
i have an old readynas rnd4000 nvx.
i have just replaced it with a new nas and want to re-purpose the old one as a straightup backup - using raid 0.
it is a funny configuration: 2 discs of 500bg each; and a 3rd disc of 2tb (don't ask...!).
the total amount of data is 810gb. currently using x-raid.
is there a way to move all the data onto one disc, then re-format the other two as raid 0?
or is there any way to change the raid type without losing the data?
  • StephenB's avatar
    No, you'll have to lose data.  Or add another 2 TB disk to the array, which will bring you to 3TB (~2.7 TiB) volume size.
    • unita's avatar
      unita
      hi Stephen, thanks for the speedy reply. could you please explain the significance of 3tb volume capacity in this context?
      cheers,
      s
      • bedlam1's avatar
        bedlam1
        Prodigy
        Maybe you should do a few "what if's" with this TOOL
        Hover over the "capacity" for detailed info
ProSupport for Business
