- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
fvbackup crashes, stalling further backup, disables graceful shutdown
- Mark as New
- Bookmark
- Subscribe
- Permalink
ReadyNAS 314 with Firmware 6.9.5 Hotfix 1
I have a problem with backup jobs crashing and freezing ReadyNas from time to time. These jobs back up various ReadyNas shares to a portable USB drive.
Once in a while, the jobs will get stuck. The timing of the problem seems completely random.
I have periodically run DEFRAG and BALANCE without any issue.
Please help me get some insight in this issue. How do I resolve this?
Thank you.
This is how it goes:
(a) The first backup job will start
(b) "/frontview/bin/fvbackup" will crash (segmentation fault) - see log below
(c) The log will have a stack trace
(d) In the stack trace, the RIP will have this string "ufsdapi_file_flush+0x253/0x2a0 [ufsd]"
(e) The small status display screen will also display "ufsdapi_file_flush+0x253/0x2a0 [ufsd]"
At this point, all future backups will stop.
(a) The ReadyNas shares will remain accessible from my Windows PC, but
(b) the admin web page will be inaccessible from a browser.
(c) I shall be able to ssh into the ReadyNas and check logs etc.
(d) Most significantly, once this happens, there is no way of gracefully shutting down the Nas
(e) The only possibility is a forced shutdown by "Press and hold the Power button for 5 seconds"
(f) Issuing a "shutdown -P" command after ssh'ing to the Nas does not shut it down.
(g) The force shutdown makes the attached portable USB drive read-only.
(h) It's probably not good for the file system either.
******************** LOG SECTION - START ************************
Mar 03 01:05:11 MITRANAS fvbackup-q[3515]: cmd=/frontview/bin/fvbackup -e 27
Mar 03 01:05:11 MITRANAS fvbackup-q[3515]: Create a readonly snapshot of '/data/Documents' in '/data/._share/Documents/.snapsho
t/b_1583215511_21184'
Mar 03 01:10:56 MITRANAS dbus[2832]: [system] Activating service name='org.opensuse.Snapper' (using servicehelper)
Mar 03 01:10:58 MITRANAS dbus[2832]: [system] Successfully activated service 'org.opensuse.Snapper'
Mar 03 01:14:25 MITRANAS clamd[32081]: SelfCheck: Database status OK.
Mar 03 01:17:03 MITRANAS CRON[21799]: pam_unix(cron:session): session opened for user root by (uid=0)
Mar 03 01:17:03 MITRANAS CRON[21803]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Mar 03 01:17:03 MITRANAS CRON[21799]: pam_unix(cron:session): session closed for user root
Mar 03 01:17:28 MITRANAS connmand[2999]: ntp: adjust (slew): -0.192048 sec
Mar 03 01:24:25 MITRANAS clamd[32081]: SelfCheck: Database status OK.
Mar 03 01:28:58 MITRANAS kernel: general protection fault: 0000 [#1] SMP
Mar 03 01:28:58 MITRANAS kernel: Modules linked in: ufsd(PO) jnl(O) vpd(PO)
Mar 03 01:28:58 MITRANAS kernel: CPU: 1 PID: 21184 Comm: fvbackup Tainted: P O 4.4.157.x86_64.1 #1
Mar 03 01:28:58 MITRANAS kernel: Hardware name: NETGEAR ReadyNAS 314/ReadyNAS 314 , BIOS 4.6.5 01/07/2013
Mar 03 01:28:58 MITRANAS kernel: task: ffff88007e665400 ti: ffff8800783ec000 task.ti: ffff8800783ec000
Mar 03 01:28:58 MITRANAS kernel: RIP: 0010:[<ffffffffa001e953>] [<ffffffffa001e953>] ufsdapi_file_flush+0x253/0x2a0 [ufsd]
Mar 03 01:28:58 MITRANAS kernel: RSP: 0018:ffff8800783efb80 EFLAGS: 00010202
Mar 03 01:28:58 MITRANAS kernel: RAX: 0000000000000234 RBX: ffff88003a5fd618 RCX: ffff88003a5fd708
Mar 03 01:28:58 MITRANAS kernel: RDX: 0000000000000234 RSI: ffff880063cee094 RDI: ffff88003a5fd618
Mar 03 01:28:58 MITRANAS kernel: RBP: ffff8800783efbf0 R08: ffff880063cee094 R09: 0000000000000634
Mar 03 01:28:58 MITRANAS kernel: R10: 0000000000000234 R11: 0000000000000634 R12: 0000000000000634
Mar 03 01:28:58 MITRANAS kernel: R13: 0000000000000434 R14: 0000000000000014 R15: 0000000000000034
Mar 03 01:28:58 MITRANAS kernel: FS: 00007f121bcb8a00(0000) GS:ffff88007ea80000(0000) knlGS:0000000000000000
Mar 03 01:28:58 MITRANAS kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Mar 03 01:28:58 MITRANAS kernel: CR2: 00007f64e00be000 CR3: 000000007ba6e000 CR4: 00000000000006f0
Mar 03 01:28:58 MITRANAS kernel: Stack:
Mar 03 01:28:58 MITRANAS kernel: 0000000000000000 0000000000000000 ffff880063cee000 0000000000000614
Mar 03 01:28:58 MITRANAS kernel: 0000000000000214 0000000000000434 0000000000000634 0000000000000234
Mar 03 01:28:58 MITRANAS kernel: dead000000000100 ffff88006a711000 ffff880010c7dc00 ffff88006a711220
Mar 03 01:28:58 MITRANAS kernel: Call Trace:
Mar 03 01:28:58 MITRANAS kernel: [<ffffffffa0011329>] do_delayed_tasks+0xdc/0x149 [ufsd]
Mar 03 01:28:58 MITRANAS kernel: [<ffffffffa001141f>] _lock_ufsd+0x89/0x94 [ufsd]
Mar 03 01:28:58 MITRANAS kernel: [<ffffffffa00181d6>] ufsd_file_open+0x10c/0x26e [ufsd]
Mar 03 01:28:58 MITRANAS kernel: [<ffffffffa00180ca>] ? ufsd_open_by_id.isra.8+0xfd/0xfd [ufsd]
Mar 03 01:28:58 MITRANAS kernel: [<ffffffff881106ed>] do_dentry_open+0x20f/0x2a8
Mar 03 01:28:58 MITRANAS kernel: [<ffffffff88111583>] vfs_open+0x5e/0x65
Mar 03 01:28:58 MITRANAS kernel: [<ffffffff8811d6aa>] path_openat+0xa20/0xcb4
Mar 03 01:28:58 MITRANAS kernel: [<ffffffff8811e82b>] do_filp_open+0x39/0x7e
Mar 03 01:28:58 MITRANAS kernel: [<ffffffff88128633>] ? __alloc_fd+0xaa/0x167
Mar 03 01:28:58 MITRANAS kernel: [<ffffffff88111892>] do_sys_open+0x14b/0x1db
Mar 03 01:28:58 MITRANAS kernel: [<ffffffff8811193b>] SyS_open+0x19/0x1b
Mar 03 01:28:58 MITRANAS kernel: [<ffffffff888cb38a>] entry_SYSCALL_64_fastpath+0x1e/0x8e
Mar 03 01:28:58 MITRANAS kernel: Code: 7d c8 4c 89 f0 eb 93 90 83 e1 08 74 b5 4c 89 c8 48 8b 4d 98 48 8b 55 a0 4c 89 c6
48 89 df 48 89 8a 94 00 00 00 48 8b 0b 48 89 c2 <ff> 51 10 85 c0 75 95 48 83 7d 90 00 74 8e 48 8b 75 a0 4c 8b 75
Mar 03 01:28:58 MITRANAS kernel: RIP [<ffffffffa001e953>] ufsdapi_file_flush+0x253/0x2a0 [ufsd]
Mar 03 01:28:58 MITRANAS kernel: RSP <ffff8800783efb80>
Mar 03 01:28:59 MITRANAS kernel: ---[ end trace c5f07c4159df64c5 ]---
Mar 03 01:28:58 MITRANAS fvbackup-q[3515]: Error executing backup job (job_id=27). rc=35584 errorno=2
******************** LOG SECTION - END ************************
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: fvbackup crashes, stalling further backup, disables graceful shutdown
I believe the hightlighed error is linked to the USB drive.
I'd test the USB drive in a PC. You can use vendor tools (seatools or lifeguard) and/or just try to copy files to and from the drive. Personally I'd do the full erase test in addition to the extended non-destructive test.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your response. That was my first hunch too. I might have forgotten to note in my original posting that I have been getting this for more than a error, sporadically.
So during a year of troubleshooting, I have tried out the following already, on the USB disk:
(1) As ReadyNAS renders the USB disk readonly, I would connect it to a windows PC and simply clear the code, reconnect it back to ReadyNAS. After that it will work fine for a while.
(2) Completely erase and reformat the USB disk using a Windows PC and then connect it back to ReadyNAS. After that it will work fine for a while.
(3) Replace the USB disk with a brand new one of a different brand. After that it will work fine for a while.
As I get the same symptoms back irrespective of what I do, I tend to think that it is not related to the USB disk.
Moreover, I have been running the same backup's for several years now on the same kind of USB disks. I started getting it only about a year back; after one ReadyNAS OS update. I am not sure which one.
If I may ask what exactly makes you think that the error is related to the USB drive? Is it because of the reference to ufsd?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes. Paragon's driver set is called "Universal File System Drivers", and they use ufsd in a variety of places. https://download.paragon-software.com/doc/Paragon_NTFS-HFS_for_Linux_9.5_User_Manual.pdf
This might be a result of an improper ejection (which of course is a given if the NAS crashes with the drive mounted).
@debumitra wrote:(2) Completely erase and reformat the USB disk using a Windows PC and then connect it back to ReadyNAS. After that it will work fine for a while.
I would definitely test it then.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am sorry, but I do not understand the diagnosis.
I have tried a brand new USB drive - I get the same error on that too. Please note, the error doesn't happen frequently; only once in 2-3 months.
Not just that, I have other backup jobs backing up other shares on the same USB disk. Those never fail. How can it be a disk issue if it shows up for only one backup job?
This makes me think that the issue is not with the USB disk per se.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
To be clear - it's at most a hypothesis that needs to be confirmed. If it were my own disk, I'd begin by running both the long non-destructive test and the full write-zeros/erase disk test using the vendor tools (WD's lifeguard program or Seagate's Seatools).
If you aren't running the maintenance tasks (on the volume settings wheel) regularly, you might also run the disk test for the internal drives there. The scrub task is also a good diagnostic (as it either reads or writes every sector in the data volume). Though I'd hesitate to do a scrub before confirming that I had a solid backup.
You could be correct - though the error definitely says the paragon drivers are crashing.
I have certainly had USB drives that fail in a particular range of sectors. It is conceivable that the particular share just happens to wind up on a marginal area of the disk. If the share has more churn (files changing) then it might also be the case that the specific share requires more I/O than the others.
FWIW, I have had at least one case where I found that many old files that hadn't changed since the initial backup couldn't be restored when I needed them - the copies failed when I restored from the USB drive. Personally I make sure I have at least two backups - in part to reduce the possibility that the backup hasn't silently failed.
BTW, another strategy here is to connect the drive to a Windows PC and back up the NAS over ethernet. There are free tools out there that can do that on schedule (and I think some might also be able to verify). Then you could see if the problem moves to the PC or stays with the NAS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Although I do appreciate the suggestions made by StephenB, I still believe that we don't know what is causing the crash. We do know that the Paragon driver is crashing. But why?
Is there any direct way of knowing?
To be very clear, this crash is **not regular**. It happens once in a while, sometimes after 4 months of no crash, sometimes 6 months. No pattern. It only happens with this one backup job. But it goes through without crashing if I recycle the NAS and rerun the backup job.
I know it has been a long exchange. It becomes hard to follow when the chain gets long. So to summarize:
(1) I do regulalrly run the balancing and defragmentation on the internal disks
(2) I do occasionally run the scrubbing too
(3) I did run the internal disk test on the internal disks once in the recent past.
None of that indicated any error condition.
(4) I have done complete reformatting the USB disk
(5) I have replaced the USB disk with a brand new one.
But the random and irregular crash continues.
I can't simulate the problem. It happens when it happens.
Any thought on how to get to the root cause of this will be very much appreciated.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
One thing you haven't tried (at least it's not on your list) is switching to a different USB port. If you're using the front port, then shift to one of the back ones (and vice versa).
