Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
iSCSI Authorization failure
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-04-19
10:53 AM
2011-04-19
10:53 AM
We purchased a Readynas 3100 of 8TB (5.5 TB usable storage) to use in an ESX environment of 4 ESXi servers and 25 VMs. (mainly linux, but a couple of windows servers as well.)
-I created 1 iSCSI target and 3 LUNs. (Since ESX cannot VMFS format disks larger than 2TB)
-I Enabled the "Access Control" (to support multiple hosts simultaneously)
-I did not configured CHAP authentication
Before installing the storage server in the data center I wanted to test the iSCSI connection from my windows 7 workstation.
After entering the IP address I discover the Target.
But when I want to connect I get "Authorization failure" 😞
How can that be since I haven't configured CHAP?
All information is welcome.
An extra question on the side.
I configured 1 target and 3 LUNs. is this the bast way to go? Or is it better to create 3 targets with each 1 LUN? :?
Now I can easily change this, once live in production I can't anymore.
Message 1 of 11
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-04-19
05:02 PM
2011-04-19
05:02 PM
Re: iSCSI Authorization failure
I am not sure about VMWare but I am pretty sure you need to use CHAP authentication if you enable access control.
Message 2 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-04-19
05:18 PM
2011-04-19
05:18 PM
CHAP and the access control list are different.
When you enable the ACL, you need to actually enter the IQN(this is available in the iSCSI initiator you're using) from each client to the list(enter it, then hit add, enter the next, hit add). Otherwise with the ACL activated but nothing in the list, no clients are authorized to have access to the LUN.
Message 3 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-04-19
05:26 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-04-19
10:19 PM
2011-04-19
10:19 PM
Grievous wrote: CHAP and the access control list are different.
Thx for your reply.
Do I have to configure this ACL if I connect from multiple initiators to it?
Our iSCSI network is an isolated vlan it has no security required.
I mean is this only for security purpose (so I can leave it disabled) or is this really required since I will have problems otherwise connecting with multiple ESX servers to the same LUN?
Message 5 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-04-20
10:58 AM
2011-04-20
10:58 AM
Yes, you need to add the IQN of every initiator that will be connecting. it is required for the iSCSI daemon on the ReadyNAS to use the persistent reservations needed to maintain multiple connections otherwise it'll just keep kicking the first client off once the second connects.
Message 6 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-04-20
02:14 PM
2011-04-20
02:14 PM
Grievous wrote: Yes, you need to add the IQN of every initiator that will be connecting. it is required for the iSCSI daemon on the ReadyNAS to use the persistent reservations needed to maintain multiple connections otherwise it'll just keep kicking the first client off once the second connects.
Hello,
In the meantime the device is in the datacenter. So I can configure and test it remotely.
-I created 1 target and 3 LUNs
-I added in the LUN configuration all the IQNs if the ESX servers connecting to the storage.
-On the ESX servers I added the IP address of the ReadyNAS to the iSCSI software initiator > Dynamic Discover.
-I let the ESX server do a rescan all
-After the rescan I see in the iSCSI software initiator on the ESX server in tab 'Static Discovery' the Target name of the ReadyNAS.
-But I don't see any storage volumes I can create a datastore on.
So the connection is there, otherwise the ESX servers would not see the name I configured on the ReadyNAS, but I dont have the LUNs available, although I configured the Access Control and added all the Initiator IQNs. (I used copy-paste so no typo's).
Anyone has an idea, all help is appreciated.
Message 7 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-04-20
02:29 PM
2011-04-20
02:29 PM
Can you open Frontview and go to System -> Config Backup -> Backup, download the whole thing and send that to me as if it were logs(info for that is in my signature)?
Message 8 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-04-20
11:16 PM
2011-04-20
11:16 PM
Thanks for the info you send via PM.
My problem is solved now but I want to share the solution.
The problem was this:
-Whan installing the ESX server I gave it an uppercase name.
In the IQN information, you see the hostname as part of the IQN name and it shows the hostname in uppercase.
So I did a copy-paste of that IQN name for the Access Control configuration to avoid typos.
But it seems that an IQN name is ALWAYS LOWERCASE, (This is iSCSI standard i did not know) regardless what ESX shows what the IQN name is.
I changed the IQN name to lowercase in the ReadyNAS and the volumes are now visible on the ESX server.
Maybe this could be a tip for future firmwares, to do a check when someone is entering an IQN that everything is lowercase and if needed automatically change all uppercase to lowercase.
Message 9 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-04-21
10:37 AM
2011-04-21
10:37 AM
I'll see what we can do about making a note for that. It is indeed confusing especially when the client displays mixed case.
Message 10 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-22
01:52 PM
2011-09-22
01:52 PM
Thank you for the answer!!! could not figure out what the heck i was doing wrong... guys maybe put a warning or something that everything has to be lower case.
Thank you
Thank you
Message 11 of 11
