jrakoczi's avatar
jrakoczi
readynas usb flash recovery images
Hi
Anybody knows where can I download readynas_usb_flash_recovery_4.1.4.img or previous versions?
I only found 4.1.8 and 4.1.12, but i need earlier version for v1 readynas.
Thanks
  • BrianL2's avatar
    BrianL2
    NETGEAR Employee Retired
    Hi jrakoczi,
    You can download the RAIDiator 4.1.4 here. By the way, why do you need to flash an old Firmware in your ReadyNAS?
    Kind regards,
    BrianL
    NETGEAR Community
    • BrianL2's avatar
      BrianL2
      Hi jrakoczi,
      I apologize. The link I have attached is for the RAIDiator version 4.1.4. Let me try to dig up if we have a copy of the USB Flash 4.1.4.img.
      Kind regards,
      BrianL
      NETGEAR Community
      • jrakoczi's avatar
        jrakoczi
        Hi Brian
        You are right i would need the ReadyNAS_USB_Flash_Recovery-4.1.14.img file. I just cannot find it.
        I have an older rnd 4000 v1 (readynas nv) and the update from the regular firmware zip file is always fail (unknown error), but i can do the usb flash update and right after the os overwrite. Right now i am on 4.1.12 version.
        Thanks for your help
        Jozsef
ProSupport for Business
