williams_nest's avatar
Aug 10, 2014
CPU and Fan upgrades
Hi there,
I'm new here - just wanted to confirm that my current upgrades all worked as planned.
My "old" ReadyNAS PRO 6 bought in 2012 - at first equipped with 6 X 2TByte disks - in 2013 upgraded to 6 X 3Tbyte disks.
Today I have first upgraded the firmware to 4.2.26
Replaced one of the disks with Western Digital RED 6Tbyte - just to test the compatibility
Replaced the system fan with Noctua NF-F12 PWM
Replaced the CPU fan with Noctua NF-R8 PWM
Replaced the processor from Pentium Dual Core E5300 to Xeon X3230 Core 2 Quad Q6700
Replaced the RAM with 2 X 4Gbyte Crucial with heatsink
Only minor problem was the CPU fan - it's approx 1 mm too high - but the side panel can be mounted with just a very little force.
The system and cpu temps are the same - the disk temps are 1-3 degrees (celsius) lower than before.
and the fans have gone from 1125 RPM (System fan) to 953 RPM
and 2057 RPM (CPU fan) to 788 RPM - so it's quiet like whisper -
when transcoding hirez movies the CPU fan goes to about 1400 RPM - still much less than the original outfit at idle.
I had plan on installing a permanent VGA out in the back - but my VGA header cable was too short - I am getting a longer within the next week.
The Q6700 CPU I got on eBay at $75 including shipping (Greenland)
The fans were $20 and $33 and the RAM upgrade was a bargain at $42
The first 6Tbyte disk was ...... $320 - I hope I can make a better deal with the next 5 ones :-)
Future plans: 5 more 6 Tbyte disks, longer VGA header and maybe upgrading the OS to OS6
ProSupport for Business
