jluros
Jan 18, 2018Aspirant
File search on ReadyNAS 6.9.1 doesn't allow searching home shares
The subject speaks for itself. I can search other shares, but not the users' "home shares." Is this a bug (or a feature)?
- Marc_VNETGEAR Employee Retired
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards,- jlurosAspirantI'm not sure I agree that this is the proper result/implementation. Why wouldn't the file search use file permissions to determine the result set? Every modern OS works this way.
- jlurosAspirant
No, this doesn't help. It explains why this doesn't work, but doesn't explain why File Search (and Spotlight) on private shares is not possible. This is a business-class product, and should support file searching of public and private shares. The SMB protocol has supported user-level security and authentication and encrypted communications for years.
- poko2121Aspirant
does spotlight search work for you on shares other than home folders?
