uplink
Jun 04, 2013Aspirant
How to map a network drive using ReadyNAS OS 6.x.x
Greetings,
I'm very sorry for my lame question. I even searched Your forums for the answer, but most of You guys use the ReadyNAS Duo system, not the one I have. Also, I read the users manual, spent more than 60 minutes with it, but never figured out. Would some one be so kind and explain me how do I connect a folder [I made a folder named "public" accessible for everyone/full control] to windows network drive?
In general, I tried the iP adress of the NAS dash [/] name of the folder and/also iP/admin/public but I was unsuccessfull. Any idea what am I doing wrong? Please advise and have patience with my mongrelness in configuring the Netgear ReadyNAS systems. So far I worked only with BFU systems where I had the icon "map the network drive" so I just had to click it :/ my apologies,
thank You for Your eventual replies!
Regards
uplink
Regards
uplink
- EtzAspirantYou probably need to switch dashes...
For Example:\\10.10.10.10\public
- uplinkAspirantOh, let me try that :)
that's just for main configuration
I tried in explorer [not msie, just explorer] the following:
192.168.1.235/public
192.168.1.235/data/public
192.168.1.235/admin/public
192.168.1.235/admin/data/public
192.168.1.235\public
192.168.1.235\data\public
192.168.1.235\admin\public
192.168.1.235\admin\data\public
This is always the result:
Not Found
The requested URL /admin/data/public was not found on this server.
none worked :/...what do I do wrong?
Thank You!
uplink - EtzAspirantYou forgot leading doubledashes...
Copy & paste exactly as follows to the explorer adress bar:\\192.168.1.235\public
uplink wrote:
Not Found
This makes me wonder, are you trying to access it with Internet Explorer or Web browser? - StephenBGuru - Experienced User
If you enter 192.168.1.235\admin\data\public, explorer opens Internet Explorer, and you get the URL message from IE. Just entering the IP address does the same.Etz wrote: uplink wrote:
Not Found
As posted, the correct syntax is \\192.168.1.235\public
Or just enter \\192.168.1.235, and then navigate to the share you want. - uplinkAspirantYou're great guys! Even easier than on other NAS systems. Thank You! Works like charm!
uplink
