Ozchap's avatar
Ozchap
OSStatus error 5
Hi community
Keep getting this error 'OSStatus error 5' when trying to log in from my wife's macbook air. Have no issue with iMac desktop & our son's macbook pro.
Want to backup her macbook air onto the ReadyNAS (2 x 3TB) using 'Time Machine' on her mac but cant log in.
Only error I can see in forum online relates to 'error 2' which is unrelated to our problem.
Thanks for any advice.
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello Ozchap,
    It must have nothing to do with ReadyNAS system you have. Can you post screenshot?
    Welcome to the community!
    • Ozchap's avatar
      Ozchap
      Thanks for your reply JennC
      I would agree with you as it seems the 2011 MacBook Air is not accessing the ReadyNAS properly for Timemachine to work.
      Please refer to the attached screenshot as requested.
      1 - error message
      2 - Finder directory (displays ReadyNas properly which can be accessed ok) HO-3TB-MA (AFP) for Mac. Files can be read & written to
      3 - Timemachine does not display the drive it only refers to HO-3TB-MA without the (AFP) directory which is what is needed for the Mac.
      Seems to me like I might need to contact AppleCare for support on this if there is an easy way otherwise I'll have to use another external drive.
      • JennC's avatar
        JennC
        Hello Ozchap,
        Can it access the NAS shares via SMB and/or AFP? Also, please make sure the MacBook is connected to the same network where the NAS is.
ProSupport for Business
