perky
Sep 06, 2016Aspirant
ReadyNAS Duo v1 - Full OS Partition?
I'm new to the community and seeking your help in resurrecting my ReadyNas Duo V1. Its behaviour became increasingly erratic recently and now I've lost access to the shares. Having researched the symptoms on this community, I suspect that I may have a full OS partition.
I've been using information on other posts to troubleshoot. Useful posts that I have followed to date are:
https://onlyblueatwork.wordpress.com/2012/12/04/netgear-readynas-access-recovery/
I did not have SSH enabled and am unable to install the add-on (presumably because the partition is full). I have however managed to start the NAS in Tech Support Mode (http://netgear.nas-central.org/wiki/TechSupportMode) and have been successful in Telnetting on to it using Putty. I've managed to mount the OS partition:
# /bin/start_raid.sh
# mount /dev/hdc1 /sysroot
Looking in /sysroot/var/log, I do see some big files:
-rw-r--r-- 1 0 0 4767744 messages
-rw-r--r-- 1 0 0 4603904 kern.log
-rw-r--r-- 1 0 0 8765440 daemon.log
-rw-r--r-- 1 0 0 81920 cron.log
-rw-r--r-- 1 0 0 15830829 syslog
-rw-r--r-- 1 0 0 53133312 auth.log
Now I'm nervous! What is the recommended way to clear space? Can I just delete say, auth.log?
How full is the OS partition? (df and df -i can tell you this)
It's best not to delete the log files. You can empty them using echo > filename
- mdgm-ntgrNETGEAR Employee Retired
# /sysroot/bin/df -h
# /sysroot/bin/df -i
# /sysroot/usr/bin/du -csh /sysroot/var/*
# /sysroot/usr/bin/du -csh /sysroot/var/log/*
Normally we copy log files onto the data volume before emptying them just in case the logs contain information that may be useful for troubleshooting other issues.
- perkyAspirant
Filesystem Size Used Avail Use% Mounted on
rootfs 7.7M 6.5M 1.3M 83% /
/dev/root 7.7M 6.5M 1.3M 83% /
tmpfs 16k 0 16k 0% /dev/shm
/dev/hdc1 1.9G 2.0G 64k 100% /sysroot# /sysroot/bin/df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
rootfs 2048 250 1798 13% /
/dev/root 2048 250 1798 13% /
tmpfs 7073 1 7072 1% /dev/shm
/dev/hdc1 128000 10969 117031 9% /sysroot# /sysroot/usr/bin/du -csh /sysroot/var/*
16k /sysroot/var/backups
47M /sysroot/var/cache
16k /sysroot/var/ftpd
38M /sysroot/var/lib
16k /sysroot/var/local
32k /sysroot/var/lock
1.2G /sysroot/var/log
16k /sysroot/var/mail
16k /sysroot/var/netatalk
16k /sysroot/var/opt
544k /sysroot/var/run
371M /sysroot/var/spool
16k /sysroot/var/tmp
32k /sysroot/var/www
48k /sysroot/var/yp
1.6G total# /sysroot/usr/bin/du -csh /sysroot/var/log/*
11M /sysroot/var/log/LeafP2P.log
0 /sysroot/var/log/LeafP2P.log.old
0 /sysroot/var/log/LeafP2P.log.old.old
0 /sysroot/var/log/LeafP2P.log.old.old.old
0 /sysroot/var/log/LeafP2P.log.old.old.old.old
0 /sysroot/var/log/LeafP2P.log.old.old.old.old.old
0 /sysroot/var/log/LeafP2P.log.old.old.old.old.old.old
0 /sysroot/var/log/LeafP2P.log.old.old.old.old.old.old.old
0 /sysroot/var/log/LeafP2P.log.old.old.old.old.old.old.old.old
51M /sysroot/var/log/auth.log
80k /sysroot/var/log/cron.log
64k /sysroot/var/log/cups
8.4M /sysroot/var/log/daemon.log
16k /sysroot/var/log/ddns
0 /sysroot/var/log/debug
0 /sysroot/var/log/dekoh_access.log
0 /sysroot/var/log/dekoh_access.log.old
0 /sysroot/var/log/dekoh_access.log.old.old
0 /sysroot/var/log/dekoh_access.log.old.old.old
0 /sysroot/var/log/dekoh_error.log
0 /sysroot/var/log/dekoh_error.log.old
0 /sysroot/var/log/dekoh_out.log
0 /sysroot/var/log/dekoh_out.log.old
0 /sysroot/var/log/dekoh_out.log.old.old
16k /sysroot/var/log/dmesg
32k /sysroot/var/log/exim
1.1G /sysroot/var/log/frontview
0 /sysroot/var/log/fsck.log
4.5M /sysroot/var/log/kern.log
16k /sysroot/var/log/ksymoops
0 /sysroot/var/log/lpr.log
0 /sysroot/var/log/mail.log
4.6M /sysroot/var/log/messages
0 /sysroot/var/log/mt-daapd.log
0 /sysroot/var/log/mt-daapd.log.old
0 /sysroot/var/log/netatalk.log
0 /sysroot/var/log/netatalk.log.old
0 /sysroot/var/log/netatalk.log.old.old
0 /sysroot/var/log/netatalk.log.old.old.old
0 /sysroot/var/log/netatalk.log.old.old.old.old
16k /sysroot/var/log/ntpstats
0 /sysroot/var/log/raidiator_version
0 /sysroot/var/log/raidiator_version.old
192k /sysroot/var/log/samba
0 /sysroot/var/log/slimserver.log
16k /sysroot/var/log/squeezecenter
16M /sysroot/var/log/syslog
256k /sysroot/var/log/upnp-av.log
0 /sysroot/var/log/upnp-av.log.old
0 /sysroot/var/log/upnp-av.log.old.old
0 /sysroot/var/log/upnp-av.log.old.old.old
0 /sysroot/var/log/upnp-av.log.old.old.old.old
0 /sysroot/var/log/upnp-av.log.old.old.old.old.old
0 /sysroot/var/log/upnp-av.log.old.old.old.old.old.old
0 /sysroot/var/log/upnp-av.log.old.old.old.old.old.old.old
0 /sysroot/var/log/upnp-av.log.old.old.old.old.old.old.old.old
0 /sysroot/var/log/upnp-av.log.old.old.old.old.old.old.old.old.old
0 /sysroot/var/log/user.log
1.2G total# /sysroot/usr/bin/du -csh /sysroot/var/log/frontview/*
16k /sysroot/var/log/frontview/access.log
0 /sysroot/var/log/frontview/apache-ssl.pid.old
16k /sysroot/var/log/frontview/backup
16k /sysroot/var/log/frontview/command.log
0 /sysroot/var/log/frontview/disk_smart_2016_05_29.log
0 /sysroot/var/log/frontview/disk_smart_2016_06_05.log
0 /sysroot/var/log/frontview/disk_smart_2016_06_12.log
0 /sysroot/var/log/frontview/disk_smart_2016_06_20.log
0 /sysroot/var/log/frontview/disk_smart_2016_07_03.log
0 /sysroot/var/log/frontview/disk_smart_2016_07_19.log
0 /sysroot/var/log/frontview/disk_smart_2016_08_01.log
0 /sysroot/var/log/frontview/disk_smart_2016_08_14.log
0 /sysroot/var/log/frontview/disk_smart_2016_08_21.log
16k /sysroot/var/log/frontview/disk_smart_2016_08_30.log
16k /sysroot/var/log/frontview/disk_usage.log
0 /sysroot/var/log/frontview/disk_usage.log.old
0 /sysroot/var/log/frontview/ecounter_2016_08_30_2209.log
0 /sysroot/var/log/frontview/ecounter_2016_08_30_2241.log
0 /sysroot/var/log/frontview/ecounter_2016_08_31_2030.log
0 /sysroot/var/log/frontview/ecounter_2016_08_31_2030.log.old
0 /sysroot/var/log/frontview/ecounter_2016_08_31_2112.log
0 /sysroot/var/log/frontview/enclosure.log
0 /sysroot/var/log/frontview/enclosure.log.old
1.1G /sysroot/var/log/frontview/error.log
16k /sysroot/var/log/frontview/memory.log
0 /sysroot/var/log/frontview/memory.log.old
0 /sysroot/var/log/frontview/partitions_2016_05_29.log
0 /sysroot/var/log/frontview/partitions_2016_06_05.log
0 /sysroot/var/log/frontview/partitions_2016_06_12.log
0 /sysroot/var/log/frontview/partitions_2016_06_20.log
0 /sysroot/var/log/frontview/partitions_2016_07_03.log
0 /sysroot/var/log/frontview/partitions_2016_07_19.log
0 /sysroot/var/log/frontview/partitions_2016_08_01.log
0 /sysroot/var/log/frontview/partitions_2016_08_14.log
0 /sysroot/var/log/frontview/partitions_2016_08_21.log
0 /sysroot/var/log/frontview/partitions_2016_08_30.log
0 /sysroot/var/log/frontview/raid_config_2016_05_29.log
0 /sysroot/var/log/frontview/raid_config_2016_06_05.log
0 /sysroot/var/log/frontview/raid_config_2016_06_12.log
0 /sysroot/var/log/frontview/raid_config_2016_06_20.log
0 /sysroot/var/log/frontview/raid_config_2016_07_03.log
0 /sysroot/var/log/frontview/raid_config_2016_07_19.log
0 /sysroot/var/log/frontview/raid_config_2016_08_01.log
0 /sysroot/var/log/frontview/raid_config_2016_08_14.log
0 /sysroot/var/log/frontview/raid_config_2016_08_21.log
0 /sysroot/var/log/frontview/raid_config_2016_08_30.log
16k /sysroot/var/log/frontview/smart_errors_hdc
0 /sysroot/var/log/frontview/smart_errors_hdc.old
16k /sysroot/var/log/frontview/smart_errors_hde
0 /sysroot/var/log/frontview/smart_errors_hde.old
16k /sysroot/var/log/frontview/spool.err
0 /sysroot/var/log/frontview/spool.err.old
16k /sysroot/var/log/frontview/spool.log
0 /sysroot/var/log/frontview/spool.log.old
0 /sysroot/var/log/frontview/spool.log.old.old
0 /sysroot/var/log/frontview/status.log-new
0 /sysroot/var/log/frontview/status.log-new.old
0 /sysroot/var/log/frontview/status.log-new.old.old
0 /sysroot/var/log/frontview/status.log-old
0 /sysroot/var/log/frontview/status.log-old.old
0 /sysroot/var/log/frontview/status.log-old.old.old
0 /sysroot/var/log/frontview/status.log-old.old.old.old
1.1G total- perkyAspirant
So: /sysroot/var/log/frontview/error.log at 1.1G would appear to be the biggest. Is this the likely culprit? What is the recommended next steps. Really appreciate your help here. Thanks so much.
