toholl
Sep 24, 2017Aspirant
ReadyNAS NV+ V2 (ARM) stuck in Boot - Normal Mode
Hello,
I am having some big troubles with my ReadyNAS NV+ V2 / RAIDiator 5.3.12
I was copying a big bunch of files when I just lost the connection to the NAS. I switched it off (normal way pressing twice the power button).
But since then, when I try to restart it just displays 'Boot Menu' after a couple of seconds and stops. Pressing the backup button I can just access the Normal option and can't move from there at all (tried reset, backup, power buttons).
RAIDar can't see it and I can't connect anymore using its IP address.
I used to have 2HDD in it used as JBOD. I have tried to remove the disks and reboot. Same issue. With only one disk. Same issue.
I would like to reflash a firmware through USB but can't find any procedure for RAIDiator 5.3 :(
Of course my unit is no more under warranty.
So I would be extremely grateful for any help.
Thanks and regards.
- Retired_MemberSep 25, 2017
Hello toholl
I uploaded USB recovery V1 version to ReadyCLOUD share,please download it at
- Retired_Member
Hello toholl
