corinbishop
Jan 14, 2016Guide
Readynas 104 won't boot. Error 354 out_of_memory. After upgrade to 6.4.1 #26323717
installed 6.4.1 from 6.2.5 yesterday. All went ok. Did all the 'calculating'. worked fine.
failed overnight with out_of_memory error 354. now won't boot.
tried reinstallOS. No luck.
totally stuck and need it for business!
did a memory test from boot menu. fails at 00:00:01
I'm guessing that's not good?- StephenBGuru - Experienced User
I'm guessing that's not good?Not good.
I think you should contact support (likely an RMA is in your future).
Slight progress.. will boot if I disconnect the network cable. I can reconnect the network cable, get an IP but then shortly after I get the error. Sounds to me like a process problem leaking memory.
- Thanks. I suspect software related as it happened after the upgrade (jeez, why did i do it??!!)
The unit will run ok until its get and ip address (and therefore starts the network services).
Ive logged a support call and they are giving me one freebie support case.
I'll let you know what happens
Cheers - mdgm-ntgrNETGEAR Employee Retired
Do you recall which services and apps you are running?
- It was smb, ntfs, rsync, UpnP, http, https, ftp, ssh
Anti-virus off. No apps - thenorthfaceAspirantHas anybody solved this yet ? It's happened to mine last night after the new firmware update keeps saying out of memory 354 ? Is there a way to go back to the old firmware
Hi thenorthface,
I have sent you a PM.The two examples of this problem in this thread are the first I've seen of this.
Generally OOM would suggest either running too much on the NAS or a memory leak.
Hi mgdm,
I'm running very little on the NAS and just using basic SMB and NTFS file sharing. I'm at 70% capacity and everything is pretty standard.
I'd say it's a software problem with one of the services. It would be great if they had a 'boot with basic' option where it could disable all but the basic admin panel and perhaps ssh services etc.
I'm running on my backup server for the moment and luckily it had mirrored before this problem.
Fingers crossed it will get fixed soon. I noticed my usual IT supplier selling the 10400 in a end of line sale cheap (€190). So I bought it just in case (I don't know if I could just move the disks over of if that would transfer the problem too?). Or could I use 6.2.5 and then move the disks? I'd hate to have to restore from backup as it would take so long but needs must.
Hiya,
I don't think downgrade is possible.
I've opened a support case with netgear so I'll let you know what happens.
So far they've asked a load of questions about ping/admin panel/raidar etc. They also asked me to try support mode:
My response to them this morning was:
_________________________________________________________________
Hi xxxxxx and thanks for taking on this problem.
I'll try to give as much detail as possible and hopefully it will help:
So:
As explained before, I did the upgrade from 625 to 641. All proceeded as planned, I was able to use the device after restart and it took a couple of hours to clear the 'calculating' status on the volume/share screen. The device continued to work until later that evening when I checked on it and found the device unresponsive. Error message was as described. All lights were on (steady) including the ACT.
I tried to reboot and got the same message on startup. I was unable to ping the machine or connect.
I tried the reinstallOS from the boot menu. It did the reinstall but it froze at the same point in boot up.
The next thing I tried was to boot it up with no network connection (i.e. unplugged everything except power).
This actually worked and the device sat there quite happily saying no-ip with all lights flashing.
I reconnected the network cable, it got an IP address but it froze with the error message 354 in under a minute. I was able to ping the machine before it froze.
I tried this a couple of times with varying levels of time 'on' before freezing again.
At no point until this morning was I able to access the admin panel.
After your email:
This morning I booted again (without the network cable) and continually pinged the device. Roughly 1 min after boot (and the no-ip message) I connected the cable, it got an IP and I was able to ping the device.
I quickly tried the admin page and was able to log in. However all I got was the main menu, it wouldn't show logs, status, performance or anything.
Within 1 minute the device then froze again.
I've tried this once more but with no success.
I also tried leaving the device with no network cable connected for longer, however eventually it froze again (just too longer to freeze than when the cable was connected)
++++++++++++++ Support mode:
I tried support mode and it shows the following with no network cable connected:
DebugMode[57550]
0.0.0.0
and with network cable connected
DebugMode[57550]
192.168.0.106
all lights (including ACT) are steady, not blinking.
I am able to ping the device ok.
I've not been able to access any system logs I'm afraid.
____________________________________________________________________
- kohdeeAdministrator
Could you possibly send me a picture of the LCD with that error message? I'm compiling a list of LCD error messages since 6.4.1 and putting them on the KB.
Out of memory on a RN104 is really easy to do, being that RN104 has 512M RAM and 256M of it is used by the system to boot, but if you're failing instantly in the boot, it does sound like bad RAM, which is only replacable by RMA of chassis
If you have a spare disk to test on and it works out fine, then it might be something software related.
kohdee wrote:Could you possibly send me a picture of the LCD with that error message? I'm compiling a list of LCD error messages since 6.4.1 and putting them on the KB.
If you have a spare disk to test on and it works out fine, then it might be something software related.sure. pic attached.
(note that it's currently error 390, previously it was 354 but I've not seen 354 come up for quite a while)
I'm thinking it's possible a RAM problem. Just seems strange it only appeared after upgrade to 641. Depends on the scope of the upgrade perhaps. It's non-downgradable so perhaps there's a change to the lower level of the hardware drivers/software/firmware etc.
I have done the mem test again and it does fail at 00:00:01 !!!
Nothing back from netgear in the last few days after I sent them a crash dump they gathered via tech support mode.
I think at this stage an RMA would be the best option to rule out hardware. I do have spare disks but I'm not convinced that a single disk with a small amount of data is really going to be conclusive as it could still be a problem with the larger file structure. The only one unusual thing I have is I had upgraded a failed disk recently from a 3TB to 4TB with a view to changing all the disks to eventually increasing the volume size XRAID styleee...
So it's gone from 3TB x4 to, 4TB+3TBx3.
It shouldn't really make any difference with xraid but who knows, it might have been a situation that was not looked at in the new firmware.- thenorthfaceAspirant
my rn104 is the same as yours but i still have the out of memory 354 error message after updating thefirmware, tech support have taken my dump file but that was a few days ago and still no answer !
- I'll see if they want to go for 642rc. However i think at this stage it would be best to let support decide. Id agree forward is best but then whatever is going to get me running is an issue too!
Hi folks.
Support have decided to disable quotas and see how I go. So far, so good. System is stable and I'm giving the unit a good thrashing - starting with syncing all the data changes Id made on the backup unit since the failure. The comparison alone will take a while.
If anyone else can suggest any other tests I could give it then let me know.
cheers
sorry. forgot to mention that I'm also on 6.4.2-T72 which I'm guessing is a specific OS versions pre RC
We have the same problem with one of our NAS here at work, so it’s not the only one.
So good to hear there might be workarounds and that it doesn’t seem to be a HW (memory) problem. Found it already a bit too coincidental that the mem failure would’ve just happened after fw upgrade. So prolly will save us RMA hassle.
Luckily the NAS was only rarely used until now for some less important backups. But it will normally get also another purpose in the very near future so would like to get it fully working again soon.
Symptoms are (almost exactly) the same as described above:
After fw upgrade from 6.2.5 to 6.4.1 system became unusable, normal boot never finishes and results in an out of memory error 354 after half an hour or so. Only hard power off (unplug) possible.
RAIDar sees the NAS booting "System starting up...", and then after a while "Management service is offline", and then after about 20 min it disappears and then shortly after also the OOM 354 error is displayed on the NAS.
During the period where it shows "Management service is offline" it shows the option buttons: Admin Page, Browse, Locate, Download Logs, Diagnostics
All of the buttons seem to work ok for a while, except for Admin Page:
Not able to access admin page: After supplying user/pw "Connecting to ReadyNAS Admin Page..." and then after a while "ReadyNAS Admin Page is offline."
Can perform locate (LEDs on), shares seem to be accessible for a short while and I can download logs a few times and Diagnostics are ok.
Tried several things:
Mem test displays 00:00:01 immediately after launching it and staying there forever. Hard reboot needed (power unplug). Don’t know if this display is pattern #, test time or error #.
Tried USB OS (re)install and OS reinstall from Boot Menu, didn’t help.Tried the boot without network cable, as above, but has the same OOM result. So this is slightly different from above.
What does kinda work is booting in "Volume read only" mode from boot menu.
In this mode the NAS seems to boot and work normal, except for the fact you can’t write to it or delete anything of course and that the calculation (of used/free space) doesn’t seem to end.
Was able to do full backup (1.5T) and later a full CRC check of the backed up data on NAS. NAS was on for about a week like this and no problems.
Also scrub, balance and defrag don’t give errors, altho wonder how this can really work on a RO volume.Yesterday tried to flash 6.4.2 RC1 but same problem still exists. Except that the error # now also is 390 instead of 354.
Volume RO is still the only mode where we can still do something.
There are no quota on the shares, so cant disable that. :(
Config:
RN10400
2 x 4TB (X-raid Raid-1) 60% Free
very basic config:
Services: SMB, HTTP, HTTPS (AV disabled)
no apps
no quota
besides admin only one extra user.
3 shares: one with about 1.5T data with snapshots and bit rot enabled. Only 36 snapshots, so not really a large number. Permissions: admin + user.
2 test ones, currently empty, (snapshots disabled, bit rot enabled). Permissions: anonymous.
LifeVibes wrote:We have the same problem with one of our NAS here at work, so it’s not the only one.
Config:
RN10400
very basic config:
no apps
no quota
2 test ones, currently empty, (snapshots disabled, bit rot enabled). Permissions: anonymous.Your situation is identical to mine so I suspect something else has been done that's not been detailed. Unless it's specificly this special version of 642+quotas off?
This problem appears to happen on the 104 in some cases when the filesystem is quite full after updating from 6.2.x.
Even if you don't have quotas enabled for any shares we do use quotas still to calculate how much space is used by snapshots for instance.
There is likely a combination of things using up memory on affected systems.
Having run into this problem if you boot into read-only mode and backup your data, do a factory default (wipes all data, settings, everything) and restore your data from backup the system should be running fine with quotas enabled.
If you run into this if you prefer we can disable quotas from the backend so that the NAS will boot in normal mode.
- Thanks for the excellent explaination. One that makes sense to me.
One last question
Would it be better for me, in the long run, to wipe and start aknew or continue as i am? I have two full backups.
Thanks again- mdgm-ntgrNETGEAR Employee Retired
Can you send me your logs (see the Sending Logs link in my sig)? There will be some information in that, that will help with answering that question.
Thanks. I've sent those logs to email in the link/instructions.
c
mdgm wrote:Can you send me your logs (see the Sending Logs link in my sig)? There will be some information in that, that will help with answering that question.
- qborosfinestAspirant
Count me in, I just ran into this as well - Reported in #26383504 .
The scenario is nearly identical to the author and other users who have reported.
Although my original ticket was regarding an NFS mount issue, I ran into this as a result of upgrading from 6.2.2 -> 6.4.1 per troubleshooting steps. There was a version I had to step through, I can't recall right now which one exactly and I cannot access any logs at the moment. So far I'm hesistant to try more reboots or boot into other modes until instructed by support.
Upon first boot after the upgrade to 6.4.1, immediately noticed "calculating" on the volume was taking quite some time and never-ending.
The unit ran for approximately 12 hours (give or take) seemingly okay in terms of r/w operations..I may have even rebooted once more in those 12 hours..in any case then the issue began at some point.
When I hard reboot (unplug) after encountering the error/crash, UI doesn't ever seem to fully load but I am able to get an active terminal. free disk was above 60%, and maybe unrelated but saw a spike in kswapd cpu usage just as it crashed. This probably happens all within a minute or two at most before hitting err 354 again. I'm not running anything out of the ordinary (ssh, https, http, rsync, nfs, smb, and No AV or other apps).
I have an abundant number of snapshots that I don't care for. Is my understanding correct that support can delete the snapshots + disable quotas to alleviate this issue? For disabling quotas is that simply a config change or something further..?
Thanks all!
- WytseAspirant
Also the Readynas 104, having trouble with the 354 out of memory message. Thought it was because i was racking up the date on my NAS but it states there is still like 4 tb of space.
I do have 4x4 tb WD Red installed.
Anyone have any news if there is a fix yet.
Kind regards.
and occuring for you immediatley after upgrading to 6.4.1?
I'm waiting for an update from Netgear, they should be accessing the box soon as I'm waiting in Tech Support Mode right now.
