wvkregten's avatar
wvkregten
Luminary
Sep 27, 2016
Readynas services greyed out of unavailable
I recently updated the Readynas (RNDU6000) to 4.2.30 with some small issues (needed 3 reboots). I had to reinstall some services like python sickrage and stuff. But thats no problem.
I have now found out that the addons screen checkboxes are not working properly. They are started but the checkbox is off. Its not a browser or cache issue, I ruled that out.
See https://i.imgur.com/yXVq2wU.png
I noticed that automatic services also do not start automatic anymore like Plex. I need to start them manually after the NAS booted. Also the update seems to have switched off write cache on all disks. I re enabled it without issues. Beside that. I cannot turn on RSync file service anymore. Also it is now  not possible anymore to enable any streaming services (window is empty) or Upnp or Bonjour (checkboxes can't be enabled..
https://i.imgur.com/Y1f1Sjg.png
https://i.imgur.com/2wQ6dWE.png
How can I fix this?
    • wvkregten's avatar
      wvkregten
      Luminary
      Using username "root".
      [email protected]'s password:
      Last login: Tue Sep 27 11:35:40 2016 from 192.168.1.62
      Last login: Tue Sep 27 11:35:48 2016 from 192.168.1.62 on pts/0
      Linux NetgearNAS 2.6.37.6.RNx86_64.2.4 #1 SMP Thu May 28 16:29:46 PDT 2015 x86_64 GNU/Linux
      Usage: grep [OPTION]... PATTERN [FILE]...
      NetgearNAS:/# df -h
      Filesystem            Size  Used Avail Use% Mounted on
      /dev/md0              4.0G  2.8G  1.1G  73% /
      tmpfs                  16K     0   16K   0% /USB
      /dev/c/c               11T  8.2T  2.8T  75% /c
      /c/Data                11T  8.2T  2.8T  75% /home/ftp/Data
      /c/HDMovies            11T  8.2T  2.8T  75% /home/ftp/HDMovies
      /c/tvshows             11T  8.2T  2.8T  75% /home/ftp/tvshows
      NetgearNAS:/#
      NetgearNAS:/#
      NetgearNAS:/#
      Please see here: https://i.imgur.com/NXzlsDq.png
      • StephenB's avatar
        It's not full now, but it is more full than typical.  I am wondering if it did fill during the install process?
        Also, can you try a df -i?  It is possible for the OS partition to run out of inodes.
      wvkregten
      Luminary
      Frontview:
      205260  ./ui/resource/language/nl/Combined.str
      205543  ./ui/resource/language/sv/Combined.str
      211529  ./ui/resource/language/pt-br/Combined.str
      212055  ./ui/resource/language/es/Combined.str
      212997  ./ui/resource/language/de/Combined.str
      214707  ./ui/resource/language/pl/Combined.str
      216201  ./ui/resource/language/ko/Combined.str
      216250  ./ui/resource/language/it/Combined.str
      223612  ./ui/resource/language/fr/Combined.str
      227697  ./bin/backup
      233912  ./bin/monitor_enclosure
      247093  ./ui/resource/language/ja/Combined.str
      315101  ./ui/resource/language/ru/Combined.str
      4888819 ./lib/Frontview.pmc
      Usr:
      6516531 ./local/tonido/ffmpeg.exe
      6516531 ./local/tonido/plugins/jukebox/ffmpeg.exe
      6839968 ./lib/locale/locale-archive
      6894180 ./sbin/mysqld
      6959276 ./bin/rpcclient
      7037724 ./sbin/winbindd
      7884372 ./bin/net
      7983656 ./bin/php5
      8214660 ./lib/apache2/modules/libphp5.so
      9055032 ./sbin/smbd
      9292434 ./local/tonido/libavformat.so.54
      10152408        ./lib/libicudata.so.36.0
      11092000        ./local/tonido/libbootstrap.so
      16709244        ./local/tonido/ffmpegv.exe
      28813665        ./local/tonido/libavcodec.so.54
      ETC:
      67811   ./frontview/addons/ui/COUCHPOTATO/JSON.pm
      67811   ./frontview/addons/ui/DDCLIENT/JSON.pm
      67811   ./frontview/addons/ui/PLEXMEDIASERVER/JSON.pm
      70002   ./frontview/wizd/skin/linkplayer/back.jpg
      70768   ./frontview/wizd/skin/linkplayer/back-delete.jpg
      74860   ./default/config/var/lib/mysql/mysql/help_keyword.MYD
      81829   ./frontview/wizd/skin/linkplayer_default/back-thumb.jpg
      81829   ./frontview/wizd/skin/linkplayer_hires/back-thumb.jpg
      82012   ./frontview/addons/ui/COUCHPOTATO/JSON/backportPP.pm
      82012   ./frontview/addons/ui/DDCLIENT/JSON/backportPP.pm
      82012   ./frontview/addons/ui/PLEXMEDIASERVER/JSON/backportPP.pm
      121230  ./frontview/wizd/skin/linkplayer_default/back.jpg
      121230  ./frontview/wizd/skin/linkplayer_hires/back.jpg
      215907  ./bash_completion
      256044  ./default/config/var/lib/mysql/mysql/help_topic.MYD
      257135  ./ssl/certs/ca-certificates.crt
      tmp and lost and found empty
      bin:
      48208   ./rm
      49168   ./dd
      49560   ./chown
      53996   ./date
      54440   ./gzip
      55984   ./stty
      60740   ./mount
      60776   ./df
      65292   ./ps
      94008   ./cpio
      96104   ./grep
      96360   ./mv
      96400   ./dir
      96400   ./ls
      96400   ./vdir
      98188   ./netstat
      104576  ./cp
      135840  ./busybox
      316216  ./tar
      712780  ./bash
      sbin:
      73656   ./tune2fs.64bit
      92992   ./hdparm
      98116   ./quotacheck
      102648  ./mke2fs
      102648  ./mke2fs.64bit
      102648  ./mkfs.ext4
      125500  ./debugfs
      137136  ./sgdisk
      227720  ./mkfs.btrfs
      229112  ./tc
      249700  ./btrfsck
      253304  ./e2fsck
      253304  ./e2fsck.64bit
      253304  ./fsck.ext4
      264604  ./isnsadm
      264676  ./btrfs
      337684  ./mdadm
      687444  ./ldconfig
      Lib:
      4366750 ./modules/2.6.37.5.RNx86_64.2.1/extra/iscsi/iscsi_trgt.ko.distrib
      4367054 ./modules/2.6.37.5.RNx86_64.2.1/extra/iscsi/iscsi_trgt.ko
      4375734 ./modules/2.6.37.6.RNx86_64.2.1/extra/iscsi/iscsi_trgt.ko
      4375734 ./modules/2.6.37.6.RNx86_64.2.1/extra/iscsi/iscsi_trgt.ko.distrib
      4377374 ./modules/2.6.37.6.RNx86_64.2.2/extra/iscsi/iscsi_trgt.ko.distrib
      4377390 ./modules/2.6.37.6.RNx86_64.2.2/extra/iscsi/iscsi_trgt.ko
      4380558 ./modules/2.6.37.6.RNx86_64.2.4/extra/iscsi/iscsi_trgt.ko
      4380558 ./modules/2.6.37.6.RNx86_64.2.4/extra/iscsi/iscsi_trgt.ko.distrib
      5164318 ./modules/2.6.37.6.RNx86_64.2.4/kernel/drivers/target/target_core_mod.ko
      5266105 ./modules/2.6.37.5.RNx86_64.2.1/kernel/drivers/target/target_core_mod.ko
      5273321 ./modules/2.6.37.6.RNx86_64.2.1/kernel/drivers/target/target_core_mod.ko
      5379145 ./modules/2.6.37.6.RNx86_64.2.2/kernel/drivers/target/target_core_mod.ko
      5445011 ./modules/2.6.33.7.RNx86_64.2.2/kernel/drivers/target/target_core_mod.ko
      5830098 ./modules/2.6.33.7.RNx86_64.2.2/kernel/drivers/target/lio-target/iscsi_target_mod.ko
      6226830 ./modules/2.6.37.6.RNx86_64.2.4/kernel/drivers/target/iscsi/iscsi_target_mod.ko
      6482798 ./modules/2.6.37.5.RNx86_64.2.1/kernel/drivers/target/lio-target/iscsi_target_mod.ko
      6491990 ./modules/2.6.37.6.RNx86_64.2.1/kernel/drivers/target/lio-target/iscsi_target_mod.ko
      6494270 ./modules/2.6.37.6.RNx86_64.2.2/kernel/drivers/target/lio-target/iscsi_target_mod.ko
      lib64:
      16112   ./libuuid.so.1.2
      18576   ./libSegFault.so
      18680   ./libnss_hesiod-2.13.so
      18728   ./libmemusage.so
      22744   ./libnss_dns-2.13.so
      24432   ./libss.so.2.0
      28816   ./libe2p.so.2.3
      31288   ./libthread_db-1.0.so
      31400   ./libnss_compat-2.13.so
      31560   ./librt-2.13.so
      39016   ./libcrypt-2.13.so
      43376   ./libnss_nis-2.13.so
      47432   ./libnss_files-2.13.so
      48848   ./libblkid.so.1.0
      51512   ./libnss_nisplus-2.13.so
      84624   ./libresolv-2.13.so
      88880   ./libnsl-2.13.so
      136752  ./ld-2.13.so
      190656  ./libcidn-2.13.so
      283168  ./libext2fs.so.2.4
      538744  ./libm-2.13.so
      752882  ./libpthread-2.13.so
      1623896 ./libc-2.13.so
      root:
      NetgearNAS:~# find . -type f -printf "%s\t%p\n" | sort -n
      0       ./_*
      0       ./.odbc.ini
      0       ./_rotate
      0       ./_txlast
      7       ./_meminst
      7       ./_rxlast
      80      ./1473976800.log
      87      ./today.log
      110     ./.profile
      399     ./.ssh/id_rsa.pub
      412     ./.bashrc
      1679    ./.ssh/id_rsa
      7935    ./.bash_history
ProSupport for Business
