mdgm-ntgr
Oct 29, 2014NETGEAR Employee Retired
Upgrading from 4.2.x direct to 6.3.5 beta
You can update direct to 6.3.5 beta
Here's how to upgrade
1. Download the firmware image linked to above and the R4toR6_Prep_Addon.bin (26 KB)
2. Install the Prep add-on via Frontview e.g. via Add-Ons > Add New
3. Install the firmware image via System > Update > Local, reboot when prompted.
The Prep add-on will get the NAS to automatically do a factory default at the appropriate point. If you don't install the Prep add-on the NAS will get stuck at some point and you will need to power down and do a factory default via the boot menu
