Orbi WiFi 7 RBE973
Reply
FVS336Gv2 Bandwidth limitations...?
Noctaire
So...this one was unexpected.
Got an FVS336Gv2, been running just fine on a 1.5M connection.  Moved it over to business class, cable at 100M down, 10M up.  Speedtest run behind the firewall show anywhere from 25M-35M down across cables connections.  Plug straight into the router (using the firewall’s cable) and speed tests come back with 100M.
Are there any limitations on the firewall itself that would throttle the speeds?
Model: FVS336Gv2|PROSAFE DUAL WAN GIGABIT FIREWALL WITH SSL & IPSEC VPN
Message 1 of 3
Accepted Solutions
DaneA
NETGEAR Employee Retired
Re: FVS336Gv2 Bandwidth limitations...?
Hi @Noctaire,
As per the FVS336Gv2 data sheet here, it has a LAN-to-WAN throughput of 60Mbps.  To take advantage of the upgraded connection which is about 100Mbps you have subscribed, you will need a firewall router that has a LAN-to-WAN throughput that is greater than 100Mbps.
DaneA
NETGEAR Community Team
Message 2 of 3
All Replies
DaneA
Hi @Noctaire,
DaneA
Message 2 of 3
Noctaire
Thanks.  That still leaves 30M unaccounted for but definitely helps me narrow the troubleshooting.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3081 views
  • 1 kudo
  • 2 in conversation
Announcements
