Reply
A6100 software for macOS High Sierra
becky1040
Follower
So far all I can find on site is Win applications.  Is there a software download for a macOS?
Model: A6100|WiFi USB Mini Adapter
Message 1 of 3
Blanca_O
NETGEAR Moderator
Re: A6100 software for macOS High Sierra
Hi @becky1040
Welcome to NETGEAR Community!
Official drivers for the A6100 adapter only works with Windows based OS.
For reference (System Requirements)
http://www.downloads.netgear.com/files/GDC/datasheet/en/A6100.pdf
Blanca
Community Team
Message 2 of 3
The last time I looked, the only USB wifi adapter that supported MacOS is still broken because Netgear is taking its time over updating it for the newest MacOS.
It has promised an update, but that was a month or so ago.
Solved: Re: compatibility macos catalina - NETGEAR Communities
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Discussion stats
  • 2 replies
  • 1727 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
