RussellJ's avatar
RussellJ
Do any Netgear USB adapters support Miracast?
On 2016-02-24, sw-hm asked "does wna3100 support Miracast?".
[According to Wikipedia, "Miracast is a standard for wireless connections from devices". It's supported by the Windows 10 "Anniversary Update" (Windows 10 Version 1607, released August 2, 2016, a.k.a. Redstone 1) and Android 4.2+.]
At that time, Netgear moderator JamesGL answered "This adapter does not support Miracast and also none of NETGEAR adapters supports miracast."
That " topic has been marked solved and closed to new posts due to inactivity", so I'll ask my question here.
Is it still the case that none of the Netgear USB adapters support miracast?
Thanks.
