Dresel's avatar
Dresel
Follower
Sep 29, 2019
compatibility macos catalina
I just bought the Nighthawk AC1900 Wifi USB adapter.  Will it work with Macos Catalina?
  • michaelkenward's avatar
    michaelkenward
    What's that?
    If you visit the support pages:
    Support | NETGEAR
    you can feed in the model number and find all the documentation for your hardware.
    • AnydCatalinaUsr's avatar
      AnydCatalinaUsr
      Tutor
      michaelkenward wrote:
      What's that?
       It's the macOS new operating system. The update was released today the 7th and it broke the use of everyones A7000 USB WiFi Adapter.
      • glamdrain's avatar
        glamdrain
        Guide
        I tryed to install the driver listed from the error shown it is trying to put it in the wrong place, so no it is not compatible with catalina
