- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC1900 WiFi Range Extender 2.4g work but 5g says no connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
So, i have the extender setup and 2.4g is connecting to the internet but 5g says no connection. I was on the latest firmware 1.0.1.112 but reverted back to an older version with no success. Any ideas why I can use 2.4 but not 5g??? Next steps?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
that "no connection" you see on the status page? That means there isn't a device (phone/tablet, etc) connected to the extenders 5ghz.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1900 WiFi Range Extender 2.4g work but 5g says no connection
What is the ide reverting to an older firmware version please? Re-introducing security vulnerabilities or loosing the ability to use the simple basic https support added on .112?
Probably the 5 GHz band was not configured properly, or the existing WiFi router handling the 5 GHz band config was changed?
@kamkam123 wrote:
Next steps?
As usual here, factory reset the EX7000 to the default config, and reconfigure the unknown to us connections to the primary Wi-Fi router from scratch again. Consult the fine documentation FMI.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What router do you have?
What method of setup did you use?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have done the factory reset and updated back to the latest firmware, but it still only shows 2.4 as connected to the internet and not 5g
- Mark as New
- Bookmark
- Subscribe
- Permalink
AC1900 EX7000
I used the Netgear sotware to setup the extender and did a smart setup
- Mark as New
- Bookmark
- Subscribe
- Permalink
that is the extender. but what router is it connected to?
Got a screensnip of the extender status page from the GUI?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here is the status from the extender status page
Let me know if any other info would be helpful
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
also, the extender connects to the
G36
SURFboard® DOCSIS® 3.1 Gigabit Modem & Wi-Fi® 6 Router
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks I see your point. I can connect to the 5g from the basement maybe because it's farther away from the router?
But I can't connect to the extender by choice when I am upstairs closer to the router. Not sure I understand it all but it works for those devices farther away
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
