× NETGEAR would like to hear from you about specific features so we can improve your experience. To participate in this survey please click HERE.
Reply
AX1800 wifi mesh extender ethernet ports
britman98
Guide
Just purchased the AX1800 (EA20) which I have setup and appears to be working fine!  My issue is the ethernet ports don't appear to be working, is there a setting I need to check? I have set up this device through the Nighthawk app and firmware is updated. Thanks for any help.
Message 1 of 16
CrimpOn
Guru
Re: AX1800 wifi mesh extender ethernet ports
Message 2 of 16
Guru
What router did you connect it to?
Did you set it up using wps, the installation assistant, or using the app?
What firmware is on it?
Have you tried other devices?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 3 of 16
britman98
Guide
Router is:  Netgear Nighthawk R6900P
as previously mentioned I set it up with the Nighthawk app.
The firmware updated as soon as it was setup.
Message 4 of 16
britman98
Guide
yes it is.
Message 5 of 16
Guru
Have you tried setting it up using the installation assistant and not the app or wps?
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
Message 6 of 16
britman98
Guide
I have set it up twice once with the app and again with the installation assistant, still no joy.
Message 7 of 16
CrimpOn
Guru
WiFi extenders with Ethernet ports typically "just work".  (i.e. no setting or setup required). How have you determined that these ports are not working?  (what was connected? Symptoms?  - error message? what?)
I love my Orbi.
Message 8 of 16
britman98
Guide
I have tried a couple of devices including my laptop, its like the ports are there but they are not hooked up, just dead! No error messages, nothing!
I am thinking about returning it and getting my money back.  Thanks for your help.
Message 9 of 16
CrimpOn
Guru
I agree. It is defective.
I love my Orbi.
Message 10 of 16
britman98
Guide
I finally figured it out, turned off “smart connect”. Went through setup again and they were working!
Thanks again!
Message 11 of 16
Guru
I'm glad it works but you shouldn't need to turn off smart connect for it to work. It should work with it enabled.
If you're still within your 90 days of free support window, you could contact netgear. Maybe theres a different firmware for it.
What actual version are you on?
Message 12 of 16
britman98
Guide
I agree, I'm just happy they work.
Message 13 of 16
creastysomp
Initiate
Message 14 of 16
Guru
again, glad their working but you shouldn't need to disable smart connect.
If you're needing to do so, I'd recommend contacting support so they're aware of the issue.
You can also mark it resolved if it fixed your issue.
Message 15 of 16
britman98
Guide
Thanks, will do.
Message 16 of 16
Discussion stats
  • 15 replies
  • 299 views
  • 3 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
