Blanketyblank
Jun 15, 2018Aspirant
Can’t find netgear WiFi network
Just bought a new range extender and can’t find the netgear WiFi network - any suggestions please? I (have to set up manually too as no WPS...
- BlanketyblankAspirantThis appears to be showing up as iinet network but it’s a secure network so I can’t connect? Have done factory reset on the extender but still shows the same... a.m. in Australia if that makes any difference...
- DexterJBNETGEAR Moderator
Hi Blanketyblank,
Welcome to the community!
1. Have you tried using another device (Android, iOS, tablet, laptop)?
2. Please make sure a proper factory reset is done. Page 34 of the user manual on this may link help out.
Dexter
Community Team
Hi Blanketyblank,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- dmfitzAspirant
It all works until I try to connect the WPS on the Extender with the modem. Green light is flashing, etc. but goes out in two minutes without the router link green light coming on?????
Hi dmfitz,
1. To confirm, is the model number of your device the EX6400?
2. What is the firmware version?
3. The extender can connect the a router/gateway and not a stand-alone modem. What is the model number of your modem?
4. Does your other device (modem) support WPS?
Dexter
Community Team
