dmilinevskyi
Mar 22, 2018Aspirant
Can't get ip address
My problem is very similar to another issue when a client can't reconnect to the network
I don't consider static ip assignment is a solution.
I have to reboot the repeater a couple of times a day because some of my devices can't properly get ip address from DHCP server.
There are no issue with signal strength, it's really good :+1:!
I don't use fast lane, the extender is connected to the router using 5GHz chanel only (although both 2.5GHz and 5GHz are used for "repeating"). Extender is running latest FW (although I've had similar issues before FW upgrade for spectre/meltdown issues). I don't use same SSID for router and extender but I use same SSID for 2.4GHz and 5GHz channels. Access scheduler is not enabled.
I didn't find where I can do a diagnostic report though.
Let me know if I can help somehow to debug the issue. Honestly it's quite annoying as to disconnect other members of my family if one of them is having troubles connecting to the network.
- jvasanth1984Virtuoso
Hi dmilinevskyi,
This may occur if your extender is not getting better connection from your router. Since your extender is connected only to 5GHz of your router, please change 5GHz channel on router to see if that resolve your issue.
- dmilinevskyiAspirant
Thanks jvasanth1984
Good point!
Previously I've been using automatic channel selection on the router side but it caused problems as repeater didn't catch up if router decided to swap the channel.
So I've hardcoded it to 36. I've changed it to 52. Unfortunatelly I can't change the channel on the extender (I don't really understand why this options is not available).
I'll post an update after I finish my experiments (a couple of days to ensure that the "fix" is stable).
Hi dmilinevskyi,
Extender will not have its individual channel since it is extending router's signal because of which you'll not have an option on extender to modify wireless channel on extender.
