Hilly68's avatar
Hilly68
Can't print wirelessly via PC where both are connected to WAC120
Hi All,
Since we changed our Wireless access point to a WAC120, PC's that are connected to it wirelessly, cannot connect to a printer that is also connected to the WAC120 wirelessly.... why is this?
My PC's that are connected wirelessly to our main wireless network downstaires or hard wired downstairs can print to it, and also, the PC's that are connected wirelessly to the WAC120 can print to the printer that is connected wirelessly to the network downstairs....
Any idea's?
We have to have the WAC120 in our lof of the main house as our router is in my office which is in an extention, so the wireless signal is too weak to cover all of our house.  The WAC120 is on a CAT5 cable that goes from our router, up to the loft, to the WAC120.
  • StephenB's avatar
    Normally questions on this product should be posted in the business wireless subforum.
    • Can you ping the printer's IP address from PCs on both networks?
    • Have you tried removing the printer from a PC setup, and then add it again?
    • Hilly68's avatar
      Hilly68
      Hi There,
      If I ping the printer (on WAC120 - Wifi 2) from my main PC which is hard wired onto the main router downstairs it works no problem.
      If I pint the Printer (on WAC120 - Wifi2) from the upstairs PC, also on WAC120 WiFi 2, it instantly fails
      If I ping the printer (on Wac120 - Wifi 2) from the upstairs PC when it's connected to the down stairs Router Wif (Wifi 1) it works, and prints.
      The problem is that the down stairs signal is too weak and often not strong enough to give internet access.
      I've updated Win10 and updated the drivers for the TP-Link network adaptor in the up stairs PC
      I've also tried countless ways and times to remove and re-add printers
