× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX3110 Install
EX3110 Install
When installing my recently purchased Netgear EX3110 I get both Power/WPS lights solid green. The wifi name/s 2.4Ghz/5Ghz comes up. I enter my password for my router and I keep getting invalid password. The Router light isnt on and Ive tried EVERY outlet in my livingroom even 3-5’ from my router. Once it told me to reset my router so I reset everything. What gives? Fixing to take this POS back to Corrupt Walmart and try my luck on corrupt Amazon.
Message 1 of 7
Accepted Solutions
Guru
Re: EX3110 Install
Hmmm. Sounds familiar.
D-Link host router?
Have you disabled Smart Connect on the host router then used the NIghthawk app to get it connected to the host router? If you did and the extender isn't working right at a far distance, I'd consider taking the extender back and trying a another one...
Message 3 of 7
All Replies
Guru
Re: EX3110 Install
Did you set it up using the push button WPS option?
If so, factory reset the extender  and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
Message 2 of 7
Guru
Re: EX3110 Install
D-Link host router?
Message 3 of 7
Re: EX3110 Install
Yes it was Push button WPS. I reached out to my son and he said my new D-Link Router has Smart Connect and to disable it. Once I did that It worked properly. Thx for the reply!!
Message 4 of 7
Re: EX3110 Install
That worked!!!
Message 5 of 7
Guru
Re: EX3110 Install
Awe, glad he helped you get it working.
Enjoy. 😉
Message 6 of 7
Deopena
Re: EX3110 Install
Not at all
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1123 views
  • 6 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
