× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
EX5000 compatibility with Xfinity Arris XB3 Gateway
DWBSr
Initiate
Is the Netgear Extender compatible with Arris XB3 Gateway?
The extender that Netgear sells is expensive.
Message 1 of 5
Guru
Re: EX5000 compatibility with Xfinity Arris XB3 Gateway
Theoretically it should work fine. I say theoretically just because I've never used that gateway/extender but it should work.
Did you just buy that gateway? Because its a bit older/lower spec'd
Message 2 of 5
DWBSr
Initiate
Thanks for responding.
I rent the gateway from Xfinity. Can’t remember how old. 3 to 4 years.
Have been thinking about buying one. I am hesitant as I don’t want Xfinity blaming any problems on me.
Open to informed suggestions.
Message 3 of 5
Guru
If you've been renting for that long, you should be able to get it upgraded.
I'd contact them through chat/calling and ask about an upgrade to the XB7 or XB8 modem.
If you're renting, they tend to keep it a bit more current. Might just need that reaching out on your part
Message 4 of 5
Guru
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 742 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
