×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
EX6100v2 will not connect to router
afmarsh
Guide
After reading back in this forum I see a lot of people having the same issue as I am for quite some time, with no resolution (I did reply to one from the other day).
My EX6100v2 has been working fine for the past 13 months. Two days ago the router LED went blank. I tried everything to get it back to life - factory reset(s), setup with WPS, Installation assistant and Nighthawk app with no luck. The extender sees the router, sets up the two EXT networks, but never gets an internet connection.
i have a FIOS Quantum Gateway Router - also 13 months old. Planned obsolescence? Hope not.
Message 1 of 8
Accepted Solutions
jasonmc100
Re: EX6100v2 will not connect to router
@afmarsh
I managed to solve my issue. I was also experiencing connectivity issues with select other devices which were all previously on the netowrk without issue. I ran across this in the Fios community and it worked. After making these changes, all devices including my EX6100v2 connected almost immediately after the updates went through. Appoligies for not giving credit to the user who posted the solution in the Fios community.
"...see if disabling SON helps by logging into router at myfiosgateway.com and go to Wireless Settings/Advanced Security Settings/ Other Advanced Wireless Options/Self-Organizing Network Enabled and set to Off"
Message 5 of 8
All Replies
afmarsh
Guide
Dang I just realized the unit was bought in April this year. Is this a warranty issue maybe then??
Message 2 of 8
afmarsh
Guide
They're sending me a replacement. Something tells me there's problems with this model they're aware of...
Message 3 of 8
jasonmc100
I'm having the same issues...just researching the boards but have done all the same troubleshooting. Just stopped working on 9/14 or 9/15. Also using Fios gateway with the EX6100v2.
Model: EX6100|AC750 Dual Band WiFi Range Extender
Message 4 of 8
jasonmc100
@afmarsh
Message 5 of 8
afmarsh
Guide
hmmmm that's when mine went down too. Weird.
I'll know soon if mine was defective, they're replacing it since it's under a year old. Will update here.
Message 6 of 8
afmarsh
Guide
Off to try that.
Message 7 of 8
afmarsh
Guide
Thank you SO much, that worked! Kudos to the person on the FiOS site, too.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1418 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
