× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
EX6110 Setup
Souwester
Tutor
EX6110 Setup
I've followed the set up instructions, lights come on etc, I can 'see' the SSID plus EXT (both 2G and 5G) but when I enter the password (same as for the router) it comes up with 'Incorrect password ...'
Can't get beyond here, so help please.I have reset bothe the router and the extender with no change.
Thanks,
Model: EX6110|AC1200 Dual Band WiFi Range Extender
Message 1 of 6
Guru
Re: EX6110 Setup
did you set it up using wps?
Sadly, to frequently wps gets coded different between manufacturer's (it shouldn't).
In those cased, try factory resetting the extender and installing it using the installation assistant instead.
Message 2 of 6
Souwester
Tutor
Re: EX6110 Setup
Thanks for reply, but that's not working either - i can't get mywifiext page to load, have tried the 192.168.1.3 approach also, just not happening.
Message 3 of 6
Guru
Re: EX6110 Setup
the "192.168.1.3" approach?
I mean push and hold reset for 7-15 seconds while its powered on.
Then follow the installation assistant. heres a video.
https://www.youtube.com/watch?v=yJVklshxBMk
Message 4 of 6
Souwester
Tutor
Re: EX6110 Setup
I did another reset, and this time managed to connect through the Netgear_ext. The wizard appeared, so I have been able to get the EX6110 running now. Don't know why it wouldn't do it for several previous attempts, but OL now. Thanks for your help.
Message 5 of 6
Guru
Re: EX6110 Setup
Glad it worked!
If you mark it solved, it'll keep others from wasting time trying to fix an already fixed issue 🙂
Message 6 of 6
Discussion stats
  • 5 replies
  • 2039 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
