kencpo's avatar
kencpo
EX6150/AC1200 WiFi range extender
Everything was working great after I set it up theEX6150/AC1200 WiFi range extender.  via WPS button on my router. This was 2 months ago. All of I sudden I can only connect with 5G.  2G connects for a second and then disconnects.  I need to use 2G in the further reaches of the range.  I restored factory settings with same results.  I again restored factory settings and did set up with the Netgear Genie.  Same results.  Any help is appreciated.
  • Have you tried the fastlane settings and make the extender only broadcast the 2.4ghz?
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    DarrenM
    • kencpo's avatar
      kencpo
      Thanks.  Problem seems to be solved.  There was an update when I opened www.mywifiext.net.  I unchecked 5Gbut I still can connect with 5G  I can even toggle between the 2 bands.
