× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
EX7000 iOS connectivity issues
BudDieselman
I've researched and read posts of other EX7000 and iOS users having the same issue. I have uploaded older firmware versions and still have limited connectivity with my iOS devices. I am able to connect to my extended network, but certain apps and safari do not work. Are there any remedies for this issue?
Thanks
Model: EX7000|AC1900 WiFi Range Extender
Message 1 of 7
schumaku
Guru
Re: EX7000 iOS connectivity issues
Have changed the EX7000 to the defaults and reconfigured from scratch? An extender is a pure Layer 2 connection, unlikely to interfere with iOS Apps and/or Safari browser.
Message 2 of 7
BudDieselman
I have reset the extender and run setup numerous times. Im assuminh that it goes to default settings when the reset button is pressed?
Message 3 of 7
BudDieselman
Any other suggestions?
Message 4 of 7
BudDieselman
Still having the same issue. Any suggestions?
Message 5 of 7
Bendeego
Guide
I have had the same issue ,on my EX7000.  I could not connect my Ipad to the 2.4 ghz channel ,nor could I connect my smart tv to the extender either,
i solved the problem by changing the security settings to WPA-PSK Tkip Wpa2 Psk AES ,,
i have a EX6200 that had the same trouble and this changed fixed that also,
this problem arose after upgrading both units to latest level of firmware,,
hope this helps
Regards
Peter H
Message 6 of 7
BudDieselman
This worked! Thank you!
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1528 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
