GarryJC's avatar
GarryJC
Tutor
Nov 24, 2022
EX7700 Not broadcasting 5Ghz
My Ex7700 was working fine, when opening any wifi setting it displayed 2.4 & 5 Ghz options to connect to.
I have just upgraded to a new router, now it only offers a 2.4Ghz option but shows that it is connected to the 5Ghz router.
I have pressed the WAP key 4or5 times & no change!
Any ideas please?
  • so it'll setup in a mesh configuration with the ssid's being combined. You can separate them if you'd like or leave it and let devices band steer between the 2x bands.
