- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Extender compatible with ORBI..?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was recommended a Nighthawk EX7700 without using the MESH functionality.
However after being on the phone for over 2 hours to Netgear support over the last two days I’m now being told the EX7700 doesn’t work with ORBI. 😡
Does anyone have any other recommendations for a fast WiFi extender that would work with ORBI..?
Thanks in advance.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
try installing version 1.0.0.206. Factory reset it after the update.
When you set it up, hardwire into the extender for setup. Make sure to disable the mesh/one ssid feature when you set it up.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Extender compatible with ORBI..?
The orbi outdoor and orbi voice both have orbi option or extender option. You could set it up in extender option and then if you ever decided to add it into your network, you could.
I've see others who've used the mesh extenders with orbi. you just don't want to run them with the mesh mode working. just as a standard extender.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was told the EX7700 would work with ORBI as long as it wasn’t in MESH mode. I couldn’t get it working and Netgear support eventually conceded it didn’t work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you still have it?
What firmware version is on it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
others have gotten it working as well.
Which version of orbi do you have?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does that help?
Netgear talked me into setting up as a mesh router in the last call so it takes the WiFi out if it’s on now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Sandman160 wrote:
I can’t remember the firmware version right now but I tried to update it and it said it was up to date.
Does that help?
some times the auto update doesn't pull the latest firmware. That's why its always good to check.
and potentially netgear support didn't know about the newest. Do you still have it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@plemans wrote:try installing version 1.0.0.206. Factory reset it after the update.
Thank you for this. After hours on the phone with support, getting nowhere, this seems like good advice.
I've updated the firmware. I didn't reset back to factory settings because as soon as it rebooted it came back working. It connected to the Orbi, got an internet connection extended the network. Doing everything I want it to do.
I've rebooted it and it does seem to be doing everything I wanted.
So, THANK YOU. Much appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad to hear you got it working! if you mark it as solved it helps the next person find the solution quicker 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
