stratainc
Feb 11, 2018Follower
Extending Nighthawk AC1900 WiFi Cable Modem Router Combo
Just bought a Nighthawk AC1900 (24x8) DOCSIS 3.0 WiFi Cable Modem Router Combo. but it does not cover the whole house - we are not big, but there is a lot of concrete. What is the best piece of equipment to extend its reach?
- I have an Apple Airport Express Base station that can extent the wifi, but the speed drops significantly.
- I also have an Apple Airport Extreme Base Station - is it possible to use that in some way?
Or ultimately do I need a mesh device, and if so, which one?
Hi stratainc,
You may look into the option of using the Airport Extreme as an extender. The links below may help out.
https://support.apple.com/en-us/HT202056
https://support.apple.com/kb/PH26268?viewlocale=en_CA&locale=en_CA
Dexter
Community Team
1 Reply
- DexterJBNETGEAR Moderator
Hi stratainc,
Dexter
Community Team
