× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
External Antenna for AC1200 WiFi Range Extender
jtwill98
Follower
A couple of questions regarding external antennas for the AC1200 WiFi Range Extender.
  1) I have a yagi 2.4 GHz antenna. Which external connector should I use, top or bottom? Does it matter?
  2) I have a connetion through the 2.4GHz channel, but the 5 GHz channel shows disconnected.
      Do I need a seperate 5GHz Antenna?
      If so, does it matter which connector is used with it?
Message 1 of 2
nhann
NETGEAR Employee Retired
Re: External Antenna for AC1200 WiFi Range Extender
Hi jtwill98,
Please note that replacing the EX6200 WiFi extender antennaes will void your warranty.
The following antenna may help: http://www.amazon.com/Super-Power-Supply%C2%AE-TL-WDN3800-TL-WN851ND/dp/B013T5TA44
Usually it is SMA type for the connector
Message 2 of 2
Discussion stats
  • 1 reply
  • 7968 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
