× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Finding MAC Address
tperk
Finding MAC Address
May seem like dumb question but I cannot figure out how to get the MAC address. 2 MAC  Addresses on Extender label seem to be for connecting other devices to the extender. I need the mac to connect extender via WiFi to my FIOS G-1100 Verizon gateway.
Thanks
Model: EX7300v2|AC2200 Nighthawk X4 WiFi Mesh Extender
Message 1 of 8
Guru
Re: Finding MAC Address
Is there any helpful information in the user manual for this?
Does the setup wizard not help you connect the extender to the main host routers wifi?
Message 2 of 8
tperk
Yes, but not to find MAC
Yes, I am connected.
Here's my problem. I have about 50 (many no name) devices conected to gateway, including the extender. I simply want to ID the Extender and change its name to "Extender." I am trying to ID all devices to make sure no one unauthorized is "borrowing" my network. It would be easier if the G-1100 has some way to sort or reorder the attached devices.
Message 3 of 8
Guru
You can look at the sticker on the extender and see the MAC address here. Then look for this address on the main host routers connected clients table...
Message 4 of 8
tperk
You must not have really read my original post.
Message 5 of 8
schumaku
Guru
There are three MAC addresses: One of for the extender wired Ethernet, one for the 2.4 GHz and one for the 5 GHz radio. Unless I'm wrong, the two WiFi radio MAC are shwon on the top of the Connected Devices in the Genie Web UI.
Message 6 of 8
tperk
Can you show me the Main MAC in this pic? The cropped out number is WPS Pin.
Message 7 of 8
tperk
My pic is here when I post. When I come back its gone. Trying again. If pic's gone, click Unit Label attachment.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1258 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
