× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Getting wired/wireless LAN working with 3g Mobile Internet
wgrushton
I'm the proud owner of a Netgear DG834 ADSL Router, a Netgear Wireless Router WPN824, and a Netgear WPN111 Rangemax Wireless USB device.;) I have one Toshiba Laptop running Win7 64bit and a PC running XP. I live in Melbourne, Australia. Until recently I had ADSL Internet going into the DG834, with an ethernet connection to the WPN824 giving me the option of both wired Lan between the two computers, wifi to two HP printers and wireless to run wifi Internet (with the help of a TotoLink N100R wireless repeater) to a TiVo box in another part of the house, and wifi to a HiMedia media centre. An ethernet connection out of the WPN824 provided Internet to an Optus HomeZone box which gave us 5 bars of reception for our mobile phones. All worked together well. However, I recently moved home to a location that cannot get an ADSL or Cable Internet connection so my only option is Telstra's 3G Mobile Wireless Internet service. So I have purchased a Telstra Elite pre-paid mobile wifi modem (which has no ethernet port) - which allows for up to 5 simultaneous wifi connections direct to the web. I've been able to get the two PCs talking to the Internet and Tivo talks to the wifi network via the repeater. However, I'm unable to get the two pcs to network together either by ethernet or wifi and I can't get the wireless printers or the HomeZone unit to work. :mad: To make matters worse I have forgotten my Network password for the (old) ethernet LAN. I'm low-mid techno savvy and think I've got some stuff setup incorrectly. Currently both the DG834 and WPN824 are disconnected. Is there any way I can use this selection of kit to get everything working together? :confused: Would it make a difference if I replaced the Telstra wireless modem with one that had one or more ethernet outputs ? Do Netgear do such a product?
Message 1 of 6
jmizoguchi
Virtuoso
Re: Getting wired/wireless LAN working with 3g Mobile Internet
duplicate
http://forum1.netgear.com/showthread.php?t=72799
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 6
tpcguy
Guide
Hi,
Try to check these devices
http://support.netgear.com/app/products/list/p3/853
Thanks,
Message 3 of 6
jmizoguchi
Virtuoso
you had WPN as access point or DG was in modem and WPN was used a router
you have to which way you had
Optus HomeZone box
and you have FEMCELL for your cell phone to use internet for your voice
you purchased MIFI or mobile broadband router unit...
I say you have MIFI
if MIFI is repeat capable devices (must support WDS-wireless distribution systems) .
also WPN824 must be V3 to support REPEAT so BOTH much meet the criteria.
DG834 has V1-V5 and all should support WDS so you could use this.
this is how concept works
http://vpncasestudy.com/download/WDS/WDS_Concept.pdf
if you MIFI can not have repeat function but existing device can will not work in results EXTENDER is ONLY options.
WN2000rpt, WN3000rp, WNCE2001 of three are choices without doing any of repeating process as extender will going the existing network.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 6
wgrushton
Default Re: Getting wired/wireless LAN working with 3g Mobile Internet
Quote:
P: Until recently I had ADSL Internet going into the DG834, with an ethernet connection to the WPN824 giving me the option of both wired Lan between the two computers
Q: you had WPN as access point or DG was in modem and WPN was used a router you have to which way you had
A: DG was modem and WPN wireless router connected to one port of the DG. Please note WPN is V1.
Quote:
P: Optus HomeZone box
Q: and you have FEMCELL for your cell phone to use internet for your voice
A: It's actually an Alcatel-Lucent 9361 Home Cell 92
Quote:
P: However, I recently moved home to a location that cannot get an ADSL or Cable Internet connection so my only option is Telstra's 3G Mobile Wireless Internet service.
Q: you purchased MIFI or mobile broadband router unit...
I say you have MIFI
A: not sure what MIFI is but the unit does not have a physical connection (eg USB or ethernet) to the laptop and has no ethernet ports. It connects with the laptop by wifi
Quote:
P: I've been able to get the two PCs talking to the Internet and Tivo talks to the wifi network via the repeater.
Q: if MIFI is repeat capable devices (must support WDS-wireless distribution systems) .
A: not sure what you are asking here
Q: also WPN824 must be V3 to support REPEAT so BOTH much meet the criteria.
A: I've replaced WPN with TotoLink N100R set as repeater and TiVo gets good signal, plus Internet works on both PCs. Internet light is blinking on HomeZone when connected to a LAN port of the N100R, but that's better than I got before but not getting Internet light soild so VOIP not working for mobiles yet. May need a reset at the suppliers end.
A: I'll take a look at these on the Netgear site - Thanks
Not tried LAN/printers again yet - getting close to New Year fireworks here in Melbourne !!:):) Have a Happy New Year :):)
Message 5 of 6
jmizoguchi
Virtuoso
Sounds like you need extender. WPN824v1 doesn't support repeat
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 7254 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
