× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
How to extend a guest network
teach49899
Follower
I am trying to extend a guest network.  I am finding that the N300 is only extending the regular network and not the guest network. Any ideas on how I can extend the guest network too?
Model: EX2700|N300 WiFi Range Extender
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: How to extend a guest network
Hello teach
You would need to factory reset the extender and set it up to extend the guest network but not both networks.
DarrenM
Message 2 of 4
dowder46
How?
Message 3 of 4
jvasanth1984
Virtuoso
Hi @dowder46,
                         You need to locate the reset hole at the side of it, use paper clip and hold it for 15-30 seconds and attempt the setup again. When you set it up, please extend only the main network or the guest network. Follow either one of the below instructions for setup.
https://kb.netgear.com/25533/How-to-install-the-EX2700-via-WPS
https://kb.netgear.com/30109/How-to-install-the-EX2700-with-NETGEAR-genie-Firmware-version-1-0-1-8-a...
Message 4 of 4
Discussion stats
  • 3 replies
  • 5204 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
