sejarb's avatar
sejarb
Linking extender to new router
I just got a new wireless router; set it up with no problem. I can't get the extender set up. The Power & WPS LEDs light green. Client Link LED will (sporadically) light green, but not the Router Link LED. Have pressed the WPS button on the router several times.The instructions for Netgear Installation Assistant don't work -- the "NETGEAR_EXT" does not show up, and what I'm supposed to see on the website given in the instructions, namely the "New Extender Setup" button, isn't there.
  • plemans's avatar
    What router did you get?
    Try factory resetting the extender. Push and hold reset for 7-15 seconds while its powered on.
    then try connecting to the netgear_ext connection and using the installation assistant.
    If you'd hit the wps on both devices, the ssid should have changed to the router ssid since thats a mesh extender.
    • sejarb's avatar
      sejarb
      EX7300 AC2200 Nighthawk X4. Thanks for the suggestion; didn't work.
      • plemans's avatar
        You put your extender but what router are you trying to connect to?
        where did it fail in the process? "didn't work" doesn't tell us anything of what happened, where it failed, or much of anything
