NLD01
Aug 24, 2018Follower
Multiple AC750 and one Channel - BAD connections
Hello,
I've installed 3 wifi extenders (Extender mode) in one house, now everywhere is wifi but the connections and speed are terrible.
I have noticed that the router is sending on ch6 and all 3 extenders are sending on channel 1. Is problem that all 3 extenders are sending on channel 1?
Can i change the channel on the AC750 Extender?
Or is it a bad idea to use multiple AC750 on one location?
Kind Regards,
Jeroen
1 Reply
NLD01 wrote:
I have noticed that the router is sending on ch6 and all 3 extenders are sending on channel 1. Is problem that all 3 extenders are sending on channel 1?I am thinking that you are using fastlane - with the 5G radio in the extenders all connecting to the 5G radio in the router. Is that the case?
One thing to check is that you are getting a good connection between the extenders and the router. 5G has higher speeds close to the router, but it doesn't carry as far as 2.4G.
What color is the router LED on the extenders? Did you try reversing the configuration? That is set up one extender to use fastlane on 2.4 ghz, and make the client-facing network 5G.
