TheSleeper2006's avatar
Jun 16, 2017
Netgear WAC120 - Maintenance Menu Missing after Firmware v2.0.5 update
Netgear Wireless AP
Model: WAC120
Firmware: v2.0.5
PC Brand: ASUS
PC OS: Windows 10
After doing the firmware update to v2.0.5 the maintenance menu is missing. All I see is the Config menu, it was there prior to doing the update
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello TheSleeper2006
    Have you tried to reload the firmware?
    DarrenM
    • NetGod's avatar
      NetGod
      Hello,
      i have exactly the same problem - WAC120 bought on 26.06.2017, firmware updated to 2.0.5 like advised on the download-page, not directly to 2.1.2.
      Reload of firmware is not possible, because the whole menu for doing that is missing, even after reboot and hard-reset.
      So if there is another way to reload the firmware we would really appreciate if you would tell us, Darren.
      Thanks!
