mwwilson
Jul 27, 2020Aspirant
Nighthawk X6S All lights blink white on front and power lite in back blinks red
Machine had been working fine for 6 months. All of a sudden all the front lights were blinking white and the power light was blinking red. Tried to reset without success. when unplugging and repluging power the light starts green and then goes to red.
Please help/Thanks!
usually when the powerline is amber its not a good sign. You might be a canadite for a tftp recovery if factory resetting doesn't work.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
- mwwilsonAspirant
Is red and amber the same on this machine?
- mwwilsonAspirant
I am getting a solid green going to a blinking red. No amber.
if you read the symptoms that could mean trying tftp:
Symptoms:
- Router not booting up properly
- Failed firmware update
- Blinking power LED
- Power LED is blinking/solid amber
- Device bricked after performing a FW update
