- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Problem with wifi extender EX6120
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried even with Ethernet and its still doesnt bond together . What to do? Is my extender broken? I had him since 2021.01 and he was wanderfull . But since a week it just stoped and i can bring him back
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Problem with wifi extender EX6120
Don't connect it to the router with ethernet. Reason why is when its hardwired into the router, it needs to be setup in access point mode and not extender mode. You'd have to re-run setup.
After your reset, did you try setting it up using the installation assistant? If not, try that. Here's a video of how to.
https://www.youtube.com/watch?v=yJVklshxBMk
you might need to factory reset 1 more time to get back to default if you were clicking on the wps button.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What firmware is on the extender?
What router are you connecting it to?
What modem/gateway is the router connected to?
If you log into your router, are you able to view the extender under the attached devices list?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it fixed!
You might mark it solved so others aren't still trying to fix it.
Plus it helps others find the solution.
