× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Reinstalling a Nighthawk AC1900 WiFi Range Extender
rj1959
I moved to a new address and now have new internet service. My range extender was setup under my old wifi network. I now can't connect it to my new network because all of the instructions say to connect to the extender's network and then go online to mywifiext.com. I can't go online while connected to that network because it doesn't exist - except in the router. In other words there is no internet connection associated with that wifi network. Any suggestions on how to change the network on my extender?
Model: EX7000|AC1900 Nighthawk WiFi Range Extender
Message 1 of 4
Guru
Re: Reinstalling a Nighthawk AC1900 WiFi Range Extender
Push and hold reset for 7-15 seconds while the extender is powered on.
That'll get you back to defaults so you can go through setup again.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
Message 2 of 4
rj1959
I tried resetting the router and now I have a network named ASUS. I tried logging into it using "admin" and "password" to no avail. Everything I can find on the support site tells me to go to their link which I can't do.
Message 3 of 4
Guru
Asus wouldn't show up unless your primary router is asus and you're using WPS.
It might just be another network showing up.
Have you tried hardwiring a pc/laptop into the extender and using the installation assistant
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 641 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
