Gili756's avatar
Gili756
Signal Strength LED stays on RED continuously
Something bizarre is happening with my unit: per instructions I located the unit in the same room with my dual band router (actually, about 2 feet away from it), and began setting it up. Now the strange part begins: first, the unit absolutely refuses to connect to the 2.4 GHz band; it only connects to the 5.0 GHz band; second, even though the unit is two feet away from the router, the signal quality LED stays on red continuously regardless of what I do.
How could the signal quality be poor, when the extender is so close to the router, and wifi analytics shows 3-4 bars of signal strength?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Make sure the unit is on the latest firmware and them you may want to try and factory reset the unit by holding the reset button for 10+ seconds then set the extender up again.
    DarrenM
    • Gili756's avatar
      Gili756
      Actually, all has been resolved without a factory-reset. It turns out my 2.4GHz band became disabled during the initial setup. Once I reran the smart setup, I was able to reactivate the 2.eGHz band. Now both bads are active, and all LED's on my extender are a steady white. I haven't had any other issues since running the smart setup. I am a very happy person right now.
