Falkie's avatar
Falkie
Slow EX2700
I have two wifi range extenders - both are EX2700 and the firmware is the latest (which is v1.0.1.72). I have FTTP with BT in UK, and when I check the speed when linked to laptop via cable to the BT router I get 500 mbps download and 71 upload which is what I should be getting. However, when I connect wirelessly via the EX2700 I only get 20.8mbps download and 13.1mbps upload. I have looked at the settings on the EX2700 and can see that the 2.4Ghz is checked. I believe that limits the speed to 142 mbps. There seems to be no option to select anything else other than 2.4 Ghz, but if the max is 142 mbps, I would have thought I should get a much better result.
Do I need to buy new range extenders ? Is the EX2700 just too old to cope with modern speeds ?
All advice is most welcome as I am uncertain of what to do.
(windows 10 up to date)
  • Your extenders only have 100 Mbps LAN port so you'll never see the speeds from your BT router. Upgrade to something better.
