× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Switching from Extender to AP (Model EX6400)
SAG1
Tutor
I have the AC1900 WiFi Extender Essentials Edition (model EX6400).
I originally set it up as a Extender which worked well but now I want the AC1900 to be and AP.
What I did was connected a Cat5 cable from my router to the AC1900 and switched the switch on the side to AP. Everything seems to be working very well and I'm seeing great WiFi signal strength and Speedtest numbers.
My question is… is there anything else I should do to do to take full advantage of my Netgear in  AP mode, or is what I did all that needs to be done?
Message 1 of 4
Accepted Solutions
Guru
Re: Switching from Extender to AP (Model EX6400)
Glad its working as it should!
If you mark it solved, it keeps others from trying to fix it still 🙂
Message 4 of 4
All Replies
Guru
I usually re-run setup but if its working as it should, I wouldn't worry about it.
did you log into its settings page to ensure its running as an access point and not still in extender mode? (shouldn't be an issue)
Message 2 of 4
SAG1
Tutor
I just got in to my settings and it does say Access Point.
That was a very easy changeover.
THANKS for the help in confirming that all is well.
SG
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 728 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
